Custom Map Service doesnot show map
1893
03-15-2014 10:42 PM
FaisalBukhari
Hi all
I am using my custom webservice  arcgis server  on local intranet .
the code is as below is working fine   with online map service (esri) .
    public void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
     // Retrieve the map and initial extent from XML layout
  mMapView = (MapView) findViewById(R.id.map);
  ArcGISDynamicMapServiceLayer dynamicLayer = new ArcGISDynamicMapServiceLayer(
    dynamicMapURL);
  map.addLayer(dynamicLayer); */
  ArcGISDynamicMapServiceLayer dynamicLayer = new ArcGISDynamicMapServiceLayer("http://gisweb2/ArcGIS/rest/services/Web_Andriod_Srv/MapServer");
  mMapView.addLayer(dynamicLayer);
Thanks in Adnance
ErikBlair
hi
if your problem is solved
could you please tell us how?
I'm facing a similar problem I guess
EricBader
Honored Contributor
In what way is it not working?
When you say "Custom", are you talking about a custom Server Object Extension?
If so, is it REST-enabled?
