Connecting to ArcSDE 10.2.1 using ArcObjects
4289
03-09-2014 09:04 PM
VikramS
Hello all,
I developed a standalone application using Arcobjects 10.1 . I used property set to open the workspace as shown below
                IPropertySet propertySet = new PropertySetClass();
                propertySet.SetProperty("SERVER", server);
                propertySet.SetProperty("INSTANCE", instance);
                propertySet.SetProperty("DATABASE", db);
                propertySet.SetProperty("USER", user);
                propertySet.SetProperty("PASSWORD", password);
                propertySet.SetProperty("VERSION", version);
                Type factoryType = Type.GetTypeFromProgID(
                    "esriDataSourcesGDB.SdeWorkspaceFactory");
                IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance
               (factoryType);
                pWorkspace = workspaceFactory.Open(propertySet, 0);
Now we have upgraded the arcsde to 10.2 . SQL Server 2012 has default instance . Now I am getting error saying "entry for sde instance not found in services file"
Is there a way to connect SDE using direct connect ? How to create ArcSDE Service ?
BrentHoskisson
What error are you getting?  There are two different ways to direct connect that I have found that works.
You can use
propertySet.SetProperty("USER", "\");
propertySet.SetProperty("PASSWORD", "\");
Or you can use
propertySet.SetProperty("AUTHENTICATION_MODE", "OSA");
Good Luck
BrentHoskisson
What error are you getting?  What are the values of your variables?  Direct connect hasn't changed that I know of.
propertySet.SetProperty("INSTANCE", "sde:<db type>:" + server);  <db type> is like "sqlserver"
propertySet.SetProperty("VERSION", "dbo.Default");
and either
or
