Run PL/SQL stored procedure (in Oracle) using arcpy
6599
03-04-2014 01:25 AM
LinaAl-Jadir
Using arcpy in a Python script, I can connect to an Oracle database (I use ArcSDESQLExecute) and then run an SQL statement (I use execute).
My question is: is there a way to run a PL/SQL stored procedure using arcpy ?
Thank you.
CarrieButler
I was able to do this with an existing SDE connection and arcpy.
import arcpy
myConn = arcpy.ArcSDESQLExecute('Database Connections/myConnectionName.sde')
mySQL = 'Call myOraPackageName.myOraProcedure()'
myReturn = myConn.execute(mySQL)
print myReturn
JamesCrandall
I don't think this is possible with arcpy.  You would have to implement a 3rd party library like cx_Oracle to do this.  We use this library but are simply building the SQL and invoking it runtime, so I don't have specific examples for PL/SQL packages or procedures.  But there is plenty of info and examples out there: http://stackoverflow.com/questions/18267935/return-variable-from-cx-oracle-pl-sql-call-in-python
CarrieButler
import arcpy
print myReturn
