Geometry object stuff
3034
02-13-2014 10:22 AM
NeilAyres
I have used this stuff before but this afternoon (because of my fading brain) I got stuck again.
This page says that using point geometry objects, you can access the X,Y,Z like this:
http://resources.arcgis.com/en/help/main/10.2/index.html#//002z0000001t000000
for row in arcpy.da.SearchCursor(infc, ["OID@", "SHAPE@"]):
    # Print the current multipoint's ID
    print("Feature {0}:".format(row[0]))
    # For each point in the multipoint feature,
    #  print the x,y coordinates
    for pnt in row[1]:
        print("{0}, {1}".format(pnt.X, pnt.Y))
If you do this, all you get is this :
>>> geom1
<PointGeometry object at 0x128e50d0[0x128e51c0]>
>>> geom1.type
u'point'
>>> geom1.X
  File "<pyshell#2>", line 1, in <module>
    geom1.X
AttributeError: 'PointGeometry' object has no attribute 'X'
This had me stuck for about an hour until, from somewhere in my aging cortex, I remembered you had to do this :
>>> geom1.type
u'point'
>>> geom1.getPart().X
37.85577369550394
>>> geom1.getPart().Y
-5.721226269422574
>>> geom1.getPart().Z
633.8880000000063
Oh, and if you try to iterate over a geometry object like in the help, that fails as well.
>>> for p in geom1:
 print p.getPart().X
  File "<pyshell#10>", line 1, in <module>
    for p in geom1:
TypeError: 'PointGeometry' object is not iterable
Dear esri, when is either the attributes of the geometry going to get fixed, or the help files when you want to actually do this stuff?
Neil
JakeSkinner
Esri Esteemed Contributor
Hi Neil,
Looks like you are trying to iterate through the shape field, which won't be possible, unless you are working with a multipoint feature class:
for pnt in row[1]:
However, you can return the XY coordinates a couple ways:
    print row[1].centroid.X, row[1].centroid.Y
or:
for row in arcpy.da.SearchCursor(infc, ["OID@", "SHAPE@XY"]):
    print row[1]
NeilAyres
Thanks Jake,
I realize that .centroid would also work. But I still think that the help could be a little less misleading.
Got my script to work by using .getPart()
Cheers,
Neil
FredSpataro
Adding my 2 cents here, since i went looking for this today:
The PointGeometry class should have either .X .Y .Z properties or a .Point property.  It doesn't make sense to use .getPart() or .centroid() or .firstPoint().  Isn't the point (no pun intended) of python to be "easy to read/write"?
I added a item to the ideas system: http://shar.es/RHjsR
