Update Cursor not working
1079
02-12-2014 05:31 AM
JordanParfitt
I have this update cursor. The code executes in LiClipse without an error at all but none of my rows update in SDE. Am I missing a step?
Jordan
# -*- coding: utf-8 -*-
# stupidtest.py
# Created on: 2014-02-06 11:56:15.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
import arceditor
arg_sdeDEV_sde = "Database Connections\\arg@sdeDEV.sde"
ARG_ACCESS_OPENING = "Database Connections\\arg@sdeDEV.sde\\ARG.DistributionSystem\\ARG.ACCESS_OPENING"
ACCESS_OPENING_Layer = "ACCESS_OPENING_Layer"
# Process: Make Feature Layer
arcpy.env.workspace = "Database Connections\\arg@sdeDEV.sde"
arcpy.MakeFeatureLayer_management(ARG_ACCESS_OPENING, ACCESS_OPENING_Layer, "", arg_sdeDEV_sde, "OBJECTID OBJECTID VISIBLE NONE;OPEN_TYPE OPEN_TYPE VISIBLE NONE;REC_INFO_NAME REC_INFO_NAME VISIBLE NONE")
# Process: Start Edit
edit = arcpy.da.Editor(arcpy.env.workspace)
edit.startEditing(False, True)
edit.startOperation()
# Process: Select and Update Data
cursor = arcpy.UpdateCursor(ARG_ACCESS_OPENING)
for row in cursor:
    if str(row.getValue("STRUCTURE_ID")) == 'None':
        row.STRUCTURE_ID = str(row.getValue("ENCLOSURE_ID"))
        cursor.updateRow(row)
del cursor, row
print 'done'
ClintDow
Maybe an overly simplistic observation, but in:
Is the 'None' meant to be a string or should it just be None for NoData? The way you have it now the conditional will only trigger if there's actually the string 'None' in those cells.
JordanParfitt
All of my code is executing. It makes it pass that if statement and even if I remove the if statement it doesn't work either. The database just isn't being updated.
for row in cursor:
Thank You
