SQL Statement in Python
2125
02-05-2014 09:09 AM
MikePowell
I am getting one of 2 errors and I don't know why. They are ORA-00911: invalid character and ORA-00933: (something about the statement not ended correctly). I am hoping a fresh set of eyes can help with it. Here is the code:
        orcl = cx_Oracle.connect("xxx/xxx@xxx")
        curs = orcl.cursor()
        database = "Database Connections\\xxx.sde\\xxx.xxx_xxx"
        sql1 = "create view RSIDs as "
        sql2 = "select * "
        sql3 = "from "+database+" where "
        sql4 = "xxxx like '%RSID%' or xxxxx like '%m%'"
        sql = str(sql1+sql2+sql3+sql4)
        print sql
        curs.execute(sql)
        curs.close()
        orcl.close()
The put x's in for the sensitive stuff but left all the slashes, comma, quotes etc... the way I have them. I tried several different ways with the slashes because I know python is funny with them but I can't get it to create the view. The statement works in SQLPLus. I am using Python 2.7. Any help is appreciated.
David_JAnderson
        sql2 = "select * "
        print sql
        curs.execute(sql)
        curs.close()
        orcl.close()
Have you checked the value of the database variable?  I think in that in the SQL statement it needs to just be the table name, without the Database Connections\\xxx.sde\\ prefix.  I am not sure why you have that as a variable as it does not seem to change.  You might also consider using a multiline string instead of a bunch of concatenated together variables.
MikePowell
Wow, that seem to be it. I took out the "database" variable and just put in the database table in the statement and that worked. It is creating the view. Thanks for the response
ShawnThorne
I was getting the same ORA-00911 & ORA-00933 errors as well.  But after removing the reference to the SDE Connection File, it worked.
import cx_Oracle
def main():
    try:
        orcl = cx_Oracle.connect("xxxx/xxxx@XXXXXX/XXXXXX")
        vw = ("COUNTRIES_PY_VIEW")
        fc = ("COUNTRIES")
        createView = (" CREATE OR REPLACE VIEW " + vw + " AS (select * from " + fc + " where country like '%States%' or country = 'Canada')")
        print ("\n Create View Syntax ---> " + createView)
        curs.execute(createView)
        print ("\n Successfully created the View '" + vw + "'.\n")
        orcl.close()
        print ("\n Completed!! \n")
        del orcl
        del curs
        del createView
        del fc
        del vw
    except arcpy.ExecuteError:
        print (arcpy.GetMessages(2))
    except Exception as e:
        print (e[0])
if __name__ == '__main__':
    main()
Results :
 Create View Syntax --->  CREATE OR REPLACE VIEW COUNTRIES_PY_VIEW AS (select * from COUNTRIES where country like '%States%' or country = 'Canada')
 Successfully created the View 'COUNTRIES_PY_VIEW'.
 Completed!!
MikePowell
Thanks for looking into it
