Opening shapefiles using FeatureTable and FeatureLayer.
7107
8
02-04-2014 09:09 PM
MarcinRoguski
recently I was trying to open a shapefile on Android and display it on the map.
I am able to load the shapefile data but displaying it on the map is a little bit complicated.
I tried to use FeatureLayer and FeatureTable to do this, but unfortunately there was no visible map on the screen.
It it even possible to display shapefiles this way ?
Here is my code for FeatureLayer:
public class ShapefileLayer extends FeatureLayer {
    private String url;
    public ShapefileLayer(String shpPath, Envelope fullExtent) {
        super(new ShapefileFeatureTable(shpPath));
        url = new File(shpPath).getAbsolutePath();
        this.setFullExtent(fullExtent);
        this.setInitialExtent(fullExtent);
        this.setVisible(true);
        this.initLayer();
        this.changeStatus(STATUS.INITIALIZED);
    @Override
    public double getMaxScale() {
        return 100000;
    @Override
    public double getMinScale() {
        return 1;
    @Override
    public String getUrl() {
        return url;
The other three classes are in next post because of the characters limit 🙂
In my MainActivity I add:
mapView.addLayer(new ShapefileLayer("/mnt/sdcard2/shp/gaz.shp", fullLayerExtent));
but I see only black screen or other layers if I add them too.
The file from sdCard is available and I am able to open it for reading and writing so no problems there.
These classes are very simple and do not include all the features I plan to add. It is made to only load geometry and display it on the map.
MarcinRoguski
And here is my implementation of the feature table:
public class ShapefileFeatureTable extends FeatureTable {
    private String tableName;
    private boolean hasGeometry;
    private SpatialReference spatialReference;
    private Map<String, Field> fields = new HashMap<String, Field>(2);
    private Map<Long, Feature> features = new HashMap<Long, Feature>();
    private SimpleLineSymbol sls = new SimpleLineSymbol(Color.BLUE, 8);
    private long featureId = 1;
    public ShapefileFeatureTable(String shapefilePath) {
        tableName = shapefilePath.substring(shapefilePath.lastIndexOf('/') + 1, shapefilePath.lastIndexOf('.'));
        //TODO: load from shp
        fields.put("OID", new ShapefileField("OID", Field.esriFieldTypeOID, 8));
        fields.put("SHAPE", new ShapefileField("SHAPE", Field.esriFieldTypeGeometry, -1));
        hasGeometry = true;
        spatialReference = SpatialReference.create(SpatialReference.WKID_WGS84);
        FileInputStream fis = null;
        BufferedInputStream bis = null;
        try {
            fis = new FileInputStream(shapefilePath);
            bis = new BufferedInputStream(fis);
            ShapeFileReader reader = new ShapeFileReader(bis);
            AbstractShape shape = reader.next();
            while(shape != null) {
                this.addFeature(new ShapefileFeature(shape,
                        null,
                        spatialReference, sls));
        } catch (Exception e) {
    @Override
    public long addFeature(Feature feature) throws TableException {
        if(feature instanceof ShapefileFeature) {
            this.validateSchema(feature);
            long id = featureId++;
            ((ShapefileFeature) feature).setId(id);
            features.put(id, feature);
            return id;
        throw new TableException("You can only add type: ShapefileFeature!');
    @Override
    public long[] addFeatures(List<Feature> features) throws TableException {
        if(features != null && features.size() > 0) {
            long[] result = new long[features.size()];
            int index = 0;
            for(Feature feature : features) {
                result[index++] = this.addFeature(feature);
            return result;
        return new long[0];
    @Override
    public void deleteFeature(long featureId) throws TableException {
        features.remove(featureId);
    @Override
    public void deleteFeatures(long[] featureIds) throws TableException {
        if(featureIds != null && featureIds.length > 0) {
            for(long featureId : featureIds) {
                this.deleteFeature(featureId);
    @Override
    public String getCopyright() {
        return "C";
    @Override
    public Feature getFeature(long id) throws TableException {
        return features.get(id);
    @Override
    public FeatureResult getFeatures(long[] ids) {
        ShapefileFeatures result = new ShapefileFeatures();
        if(ids != null && ids.length > 0) {
            List<Object> features = new ArrayList<Object>(ids.length);
            for(long id : ids) {
                features.add(this.features.get(id));
            result.setFeatures(this.features.values());
        return result;
    @Override
    public Field getField(String fieldName) {
        return fields.get(fieldName);
    @Override
    public List<Field> getFields() {
        return new ArrayList<Field>(fields.values());
    @Override
    public String getTableName() {
        return tableName;
    @Override
    public boolean hasGeometry() {
        return hasGeometry;
    @Override
    public boolean isEditable() {
        return true;
    @Override
    public Future<FeatureResult> queryFeatures(final QueryParameters queryParameters, final CallbackListener<FeatureResult> callbackListener) {
        return new FutureTask<FeatureResult>(new Callable<FeatureResult>() {
            public FeatureResult call() throws Exception {
                try {
                    FeatureResult result = ShapefileFeatureTable.this.queryFeatures(queryParameters);
                    callbackListener.onCallback(result);
                    return result;
                } catch(Exception e) {
                    callbackListener.onError(e);
                    throw e;
    @Override
    public Future<long[]> queryIds(final QueryParameters queryParameters, final CallbackListener<long[]> callbackListener) {
        return new FutureTask<long[]>(new Callable<long[]>() {
            public long[] call() throws Exception {
                try {
                    long[] ids = new long[(int) result.featureCount()];
                    Iterator<Object> iterator = result.iterator();
                    int index = 0;
                    while(iterator.hasNext()) {
                        Object obj = iterator.next();
                        if(obj instanceof Feature) {
                            ids[index++] = ((Feature) obj).getId();
                    callbackListener.onCallback(ids);
                    return ids;
                    throw e;
    private FeatureResult queryFeatures(QueryParameters queryParameters) {
        int maxFeatures = queryParameters.getMaxFeatures();
        if(maxFeatures <= 0) {
            maxFeatures = Integer.MAX_VALUE;
        List<Feature> features = null;
        if(queryParameters.getObjectIds() != null && queryParameters.getObjectIds().length > 0) {
            features = new ArrayList<Feature>(Math.min(maxFeatures, queryParameters.getObjectIds().length));
            for(long id : queryParameters.getObjectIds()) {
        Geometry g = queryParameters.getGeometry();
        if(g != null) {
            SpatialRelationship sr = queryParameters.getSpatialRelationship();
            if(sr == null) {
                throw new IllegalArgumentException("Nie podano typu relacji przestrzennej!");
            if(features != null) {
                features = GeometryUtils.filterFeatures(features, g, sr, maxFeatures);
            } else {
                features = GeometryUtils.filterFeatures(this.features, g, sr, maxFeatures);
        result.setFeatures(features);
        return result;
    @Override
    public void updateFeature(long featureId, Feature feature) throws TableException {
        if(features.containsKey(featureId)) {
            features.put(featureId, feature);
    @Override
    public void updateFeatures(long[] ids, List<Feature> features) throws TableException {
        if(ids != null && features != null && ids.length > 0 && ids.length == features.size()) {
            int index = 0;
                this.updateFeature(ids[index++], feature);
    private void validateSchema(Feature feature) throws TableException {
        //TODO
    public static class ShapefileFeatures extends FeatureResult implements Iterator<Object> {
        private List<Feature> features;
        private int index;
        private ShapefileFeatures() { }
        private void setFeatures(Collection<Feature> features) {
            if(features instanceof List) {
                this.features = (List<Feature>)features;
            } else {
                this.features = new ArrayList<Feature>(features);
        @Override
        public Iterator<Object> iterator() {
            return this;
        @Override
        public long featureCount() {
            return features.size();
        public boolean hasNext() {
            return index < features.size() - 1;
        public Object next() {
            return this.hasNext() ? features.get(index++) : null;
        public void remove() {
            features.remove(index);
    private static class ShapefileField extends Field {
        private String name;
        private int type;
        private int length;
        public ShapefileField(String name, int type, int length) {
            this.name = name;
            this.type = type;
            this.length = length;
        @Override
        public String getAlias() {
            return name;
        @Override
        public Domain getDomain() {
            return null;
        @Override
        public int getFieldType() {
            return type;
        @Override
        public String getName() {
            return name;
        @Override
        public int getLength() {
            return length;
MarcinRoguski
The ShapefileFeature class:
public class ShapefileFeature implements Feature {
    private long id;
    private AbstractShape abstractShape;
    private Geometry geometry;
    private Map<String, Object> attributes;
    private Symbol symbol;
    public ShapefileFeature(AbstractShape abstractShape,
            Map<String, Object> attributes, SpatialReference spatialReference,
            Symbol symbol) {
        this.abstractShape = abstractShape;
        this.attributes = attributes;
        this.spatialReference = spatialReference;
        this.symbol = symbol;
    /*package*/ void setId(long id) {
        this.id = id;
    public Object getAttributeValue(String fieldName) {
        return attributes == null ? null : attributes.get(fieldName);
    public Map<String, Object> getAttributes() {
        return attributes;
    public Geometry getGeometry() {
        if(geometry == null) {
            geometry = this.toGeometry(abstractShape);
        return geometry;
    public long getId() {
        return id;
    public SpatialReference getSpatialReference() {
        return spatialReference;
    public Symbol getSymbol() {
        return symbol;
    private Geometry toGeometry(AbstractShape ps) {
        if(ps instanceof PolylineShape) {
            Polyline result = new Polyline();
            PointData[] points = ((PolylineShape)ps).getPoints();
            for(int i=0;i<points.length - 1;++i) {
                Line linePart = new Line();
                linePart.setStart(new Point(points.getX(), points.getY()));
                linePart.setEnd(new Point(points[i + 1].getX(), points[i + 1].getY()));
                result.addSegment(linePart, result.getPathCount() == 0);
            return result;
        //TODO: other geometries will be implemented later
        throw new IllegalStateException("Not yet implemented!");
And at last GeometryUtils that is made to filter objects by geometry and is used in spatial queries:
public class GeometryUtils {
    private static Map<SpatialRelationship, GeometryRelationFilter> FILTERS = new HashMap<SpatialRelationship, GeometryRelationFilter>();
    static {
        FILTERS.put(SpatialRelationship.CONTAINS, new GeometryRelationFilter() {
            public boolean isRelationvalid(Geometry left, Geometry right, SpatialReference sr) {
                return GeometryEngine.contains(left, right, sr);
        FILTERS.put(SpatialRelationship.CROSSES, new GeometryRelationFilter() {
                return GeometryEngine.crosses(left, right, sr);
        FILTERS.put(SpatialRelationship.ENVELOPE_INTERSECTS, new GeometryRelationFilter() {
            private Envelope leftGeomExtent = new Envelope();
            private Envelope rightGeomExtent = new Envelope();
            public synchronized boolean isRelationvalid(Geometry left, Geometry right, SpatialReference sr) {
                left.queryEnvelope(leftGeomExtent);
                right.queryEnvelope(rightGeomExtent);
                Envelope leftEnvelope = leftGeomExtent.getXMin() <= rightGeomExtent.getXMin() ? leftGeomExtent : rightGeomExtent;
                Envelope rightenvelope = leftEnvelope == leftGeomExtent ? rightGeomExtent : leftGeomExtent;
                if(leftEnvelope.getXMax() < rightenvelope.getXMin()) {
                    return false;
                Envelope topEnvelope = leftGeomExtent.getYMax() >= rightGeomExtent.getYMax() ? leftGeomExtent : rightGeomExtent;
                Envelope bottomEnvelope = topEnvelope == leftGeomExtent ? rightGeomExtent : leftGeomExtent;
                return topEnvelope.getYMin() < bottomEnvelope.getYMax();
        FILTERS.put(SpatialRelationship.INTERSECTS, new GeometryRelationFilter() {
                Geometry intersection = GeometryEngine.intersect(left, right, sr);
                return intersection != null && !intersection.isEmpty();
        FILTERS.put(SpatialRelationship.TOUCHES, new GeometryRelationFilter() {
                return GeometryEngine.touches(left, right, sr);
        FILTERS.put(SpatialRelationship.WITHIN, new GeometryRelationFilter() {
                return GeometryEngine.within(left, right, sr);
        FILTERS.put(SpatialRelationship.OVERLAPS, new GeometryRelationFilter() {
                if(left.getDimension() != right.getDimension()) {
                    return intersection.getDimension() == left.getDimension();
                throw new IllegalArgumentException("Relacja pokrywania (overlap) jest nieokre�?lona dla różnych typów geometrii!");
        FILTERS.put(SpatialRelationship.INDEX_INTERSECTS, new GeometryRelationFilter() {
                //TODO
                throw new IllegalStateException("Relacja INDEX_INTERSECTS jest niezaimplementowana!");
    public static List<Feature> filterFeatures(Map<Long, Feature> features,
            Geometry filterGeometry, SpatialRelationship sr, int maxFeatures) {
        GeometryRelationFilter filter = FILTERS.get(sr);
        List<Feature> result = new ArrayList<Feature>(500 > features.size() ? 500 : features.size());
        for(Entry<Long, Feature> feature : features.entrySet()) {
            Feature f = feature.getValue();
            if(filter.isRelationvalid(filterGeometry, f.getGeometry(), f.getSpatialReference())) {
                result.add(f);
            if(result.size() >= maxFeatures) {
                break;
        return result;
    public static List<Feature> filterFeatures(Collection<Feature> features,
        for(Feature f : features) {
                result.add(f);
                break;
        return result;
    private static interface GeometryRelationFilter {
        boolean isRelationvalid(Geometry left, Geometry right, SpatialReference sr);
MarcinRoguski
Really? Nobody tried to read shapefiles this way using FeatureTables ?
I know I posted lots of code, but it really is not that dificult to understand 😉
Even an information that what I am doing is not possible would be valuable.
It would definitely save me a lot time.
RobertBurke
Hi Marcin,
Please have a look at this thread posts #6 and #7:
http://forums.arcgis.com/threads/94377-offline-map-viewing
And also the offline map discussion here:
https://developers.arcgis.com/android/guide/create-an-offline-map.htm
Hope this helps!
Rob Burke
cjl
you can extends GeodatabaseFeatureTable,then override all methods.
package com.esri.core.geodatabase;
public class ShapefileFeatureTable extends GeodatabaseFeatureTable{
     public ShapefileFeatureTable( ){
        super();
still use FeatureLayer,FeatureLayer only use GeodatabaseFeatureTable�??or subclass�??
public FeatureLayer(FeatureTable featureTable)
    super(false);
    if (featureTable == null) {
      throw new IllegalArgumentException("The argument featureTable cannot be null.");
    this.u = featureTable;
    if (featureTable instanceof GeodatabaseFeatureTable) {
      this.v = true;
      a((GeodatabaseFeatureTable)featureTable);
      setCredentials(((GeodatabaseFeatureTable)featureTable).getGeodatabase().getCredentials());
    } else {
      this.v = false;
    HashMap localHashMap = new HashMap();
    localHashMap.put(Integer.valueOf(0), createPopupInfo());
    setPopupInfos(localHashMap);
MotiejusViltrakis
Hello Marcin,
Have you managed to complete your task yet? I recently started looking into it myself and need some help with it.
Steb by step process of how to make a shapetable, add a shape file and display it would be great if somebody could help out
PuneetPrakash
ArcGIS Runtime SDK for Android 10.2.5 supports direct read of shape files. Feature editing is not supported at this time.
ShapefileFeatureTable | ArcGIS Android 10.2.5 API
mShapefilePath = "/shapefiles_data/Data/Points.shp";
    mSdcard = Environment.getExternalStorageDirectory().getPath();
    mMapView = (MapView) findViewById(R.id.mapView);
    mTiledlayer = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer");
    mMapView.addLayer(mTiledlayer);
    try {
      mTable = new ShapefileFeatureTable(mSdcard+mShapefilePath);
      mFlayer = new FeatureLayer(mTable);
      mFlayer.setRenderer(new SimpleRenderer(new SimpleMarkerSymbol(Color.MAGENTA, 10, STYLE.TRIANGLE)));
      mMapView.addLayer(mFlayer);
      Log.d("**ShapefileTest**", "SpatialReference : "+ mTable.getSpatialReference());
    } catch (FileNotFoundException e) {
      Log.d("**ShapefileTest**", "File not found in SDCard, nothing to load");
      Toast.makeText(getApplicationContext(), "File not found in SDCard, nothing to load", Toast.LENGTH_LONG).show();
MotiejusViltrakis
Thank you
