Command for exporting rasters to points
1471
5
02-03-2014 11:19 PM
SonjaVoncina
Hi!
Can anyone help me with Python code for exporting many rasters to points.
I have numerous raster files I want to convert to points. I want program to open every raster in a folder and save its point file to another folder, name must stay the same.
I have diffilculties defining inRaster and outRaster as I'm a newbie in Python language.
Thank you.
JakeSkinner
Esri Esteemed Contributor
There is one minor mistake in the code that Anthony posted.  The code is trying to convert the entire rasterlist to a point feature class rather than the individual raster.  Try the following:
import arcpy from arcpy import env  arcpy.env.workspace = r"C:\GIS\Projekti\Divaca_Ber_10ocen_met9\Testno\script" outworkspace = r"C:\GIS\Projekti\Divaca_Ber_10ocen_met9\Testno\script\point"  rasterlist = arcpy.ListRasters("*")  for raster in rasterlist:   arcpy.RasterToPoint_conversion(raster, outworkspace + "//" + str(raster) + ".shp", "VALUE")
AnthonyCheesman1
Hi
The 'raster to point' tool will be able to help.
A couple of questions:
1/ are all the rasters in the same directory?
2/ where do you want to store the output files?
3/ how do you want to name the output files?
It would be quite straightforward if all the rasters are in the same folder, and you want to store all of the point feature classes in the same location (ie in a folder if working with shapefiles, or in a geodatabase if working with feature clases)
The easiest thing to do would be to write a simple loop, using a list to contain all the names of the raster files.
I don't have a arcpy-enabled machine with me tonight, so the code below isn't absolutely correct or validated, however you will want to do something like this:
#import libraries
import arcpy
#set environments
arcpy.env.workspace = r'[file path to where your rasters are stored]
outworkspace = r'[file path to where you want to save outputs]
#create list
#loop thru list
  arcpy.RasterToPoint_conversion(rasterlist, outworkspace + "//" + str(raster) + "_point", "VALUE")
  #this confirms you are looking at the VALUE field of the raster, and calling the output file the same name as the raster, appended by _point.
del outworkspace, raster, rasterlist
Good luck.
SonjaVoncina
1/ are all the rasters in the same directory? YES
2/ where do you want to store the output files? In another directory.
3/ how do you want to name the output files? Same as raster file.
>>> #import libraries
... import arcpy
... from arcpy import env
... #set environments
... arcpy.env.workspace = r"C:\GIS\Projekti\Divaca_Ber_10ocen_met9\Testno\script"
... outworkspace = r"C:\GIS\Projekti\Divaca_Ber_10ocen_met9\Testno\script\point"
... #create list
... rasterlist = arcpy.ListRasters("*")
... #loop thru list
... for raster in rasterlist:
... arcpy.RasterToPoint_conversion(rasterlist, outworkspace + "//" + str(raster) + "_point", "VALUE")
... #this confirms you are looking at the VALUE field of the raster, and calling the output file the same name as the raster, appended by _point.
... del outworkspace, raster, rasterlist
Runtime error <type 'exceptions.RuntimeError'>: Object: Error in executing tool
This is the result. Is my path to folder correct (marked in red)?
JakeSkinner
SonjaVoncina
IT WORKS, IT WORKS!!
Thank you very much. 🙂
AnthonyCheesman1
Thanks Jake for picking up the error - I did notice that as I re-read the post over breakfast this morning.
Glad the process worked.
