Accessing File Geodatabase API in Python
5540
5
02-02-2014 08:50 AM
JosephArmbruster
Are you interested in using the File Geodatabase API in Python?  Well, wait no more!  You can read about it in this post:
http://libjoe.blogspot.com/2014/02/python-wrapper-for-esri-file.html
And visit the project page here:
https://code.google.com/p/file-geodatabase-api-python-wrapper/
Joseph Armbruster
MarcoBoeringa
Joseph,
You should correct the links, they error out with a 404... Interesting project by the way!
JosephArmbruster
No clue why they were clipped... now they are correct.
Luke_Pinner
MVP Regular Contributor
I searched high and low and could not find a Python wrapper for it, so I had a fresh cup of Joe and decided to dive right in.
Are you aware of the GDAL/OGR python bindings? They have supported the FGDB API for about as long as the API has been available.
JosephArmbruster
lpinner: If all you need to do is access the File Geodatabase API then this is substantially more lightweight than GDAL/OGR and exposes the original API interfaces (including those for editing).  I use GDAL almost every day but in this case I desired a more direct path to the File Geodatabase API.
JosephArmbruster
I'm going to create a simplified windows build tonight.
