SQL expression to python expression
2796
01-29-2014 10:54 PM
Tom_AndersEngebakken
Hi
I have a SQL expression that I use in Make Feature Layer in Model Builder ("HOSPITAL" = '% HOSPITALNAME%'). The expression makes a selection in a OD Cost Matrix that a patient is patient only at one hospital and not all hospitals as an OD Cost Matrix would normally do. HOSPITAL is a column in orgins in add location and HOSPITALNAME is a column in the DESTINATION to add location.
What I wonder is how this expression will be in a python script?
I've tried something like this in python in the expression field in arcpy.MakeFeatureLayer "'HOSPITAL' = '" + HOSPITAL NAME + "'". But it does not works. I don't get any error message but it only runs OD Cost Matrix normally.
Can anyone help me with this?
Regards Tom Anders
JakeSkinner
Esri Esteemed Contributor
Hi Tom,
What type of data are you working with?  i.e. Shapefile, File Geodatabase Feature Class, Personal Geodatabase Feature Class, SDE Feature Class
http://resources.arcgis.com/en/help/main/10.2/index.html#//00s500000033000000
Try the following:
"HOSPITAL = '" + HOSPITALNAME + "'"
Hi
thanks for the reply.
I work with shapefiles.
It looks like the expression you showed me worked well. But the output files  overwrites each other. What can I do to avoid this?
Here is the Python script:
# Import system modules
import sys, string, os, arcpy
from arcpy import env
#Check out the Network Analyst extension license
arcpy.CheckOutExtension("Network")
env.workspace = r"C:\Tom\Oppdrag_2014\IPLOS"
inNetworkDataset = r"C:\Tom\ELVEG_Nettverk_2013\ELVEG_Nettverk_2013.gdb\ELVEG_Nettverk\ELVEG_Nettverk_ND_2013"
outNALayer = "Foreldere_til_Barn"
impedanceAttribute = "Drivetime"
accumulateAttributeName = ["Minutes"]
FCForeldre = "io_1000_Shape.shp"
FCBarn = "Barn_1000_Shape.shp"
outLayerFile = r"C:\Tom\Oppdrag_2014\IPLOS" + "/" + "%outNALayer%" + ".lyr"
rows = arcpy.SearchCursor(FCBarn)
for row in rows:
    famnrNavn = row.getValue("famnr")
    inDestination = "BarnLayer"
    #arcpy.MakeFeatureLayer_management(FCBarn, BarnLyr)
    arcpy.MakeFeatureLayer_management(FCBarn, inDestination, "famnr = '" + famnrNavn + "'")
    lyrForeldere = "ForeldereLayer"
    #arcpy.MakeFeatureLayer_management(FCForeldre, ForeldereLyr)
    arcpy.MakeFeatureLayer_management(FCForeldre, lyrForeldere, "famnr = '" + famnrNavn + "'")
    #Create a new OD Cost matrix layer.
    arcpy.MakeODCostMatrixLayer_na(inNetworkDataset, outNALayer, "Minutes", "", "", "Minutes")
    #Load the locations as origins.
    arcpy.AddLocations_na(outNALayer, "Origins", lyrForeldere, "Name famnr #","1000 Meters", "famnr")
    #Load the locations as destinations
    arcpy.AddLocations_na (outNALayer, "Destinations", inDestination, "Name famnr #","1000 Meters", "famnr")
    #Solve the OD cost matrix layer
    arcpy.na.Solve(outNALayer,"","", "10 Meters")
    #Save the solved OD cost matrix layer as a layer file on disk with relative
    #paths
    arcpy.SaveToLayerFile_management(outNALayer, outLayerFile,"RELATIVE")
Regards Tom Anders
JakeSkinner
You can name the output layer file to something unique.  Ex:
arcpy.SaveToLayerFile_management(outNALayer, outNALayer + "_" + famnrNavn + ".lyr", "RELATIVE")
Also, when you post your code, be sure to wrap it in  CODE tags using the # symbol.  This will preserve the indentation.
I am completely new to Python so thank you very much for your help. appreciate it.
Tom Anders
