Error with create new project with arcgis sdk Qt
4065
01-24-2014 07:03 AM
mohamedajap
HI everybody,
on a Win 7 . machine (64 bit) with .NET Framework 4.5  I have installed all the components as described here:
https://developers.arcgis.com/en/qt/...on-windows.htm
but the different that i use  Visual C++Compiler 11.0 (amd64) instead of  Visual C++Compiler 11.0 (X86_amd64)
With Visual Studio 2012 express , the compiler I use is MS Visual C++Compiler 11.0 (amd64).
I can run example applications without problems. Trying to create a new project using ArcGIS Runtime SDK 10.2, I get the following error messages:
error: C1083: Cannot open include file: 'Map.h': No such file or directory
please help
cuongha
HI everybody,
please help
you need add INCLUDEPATH in file *.pro is:
    INCLUDEPATH += "C:/ProgramFile(x86)/ArcgisSDK/runtime_sdk/qt10.2/sdk/include/"
JeanneTrieu
You can also follow the steps here to copy the prf to appropriate location so the project created based on the template project finds all the dependencies:
https://developers.arcgis.com/qt/guide/integration-with-qt-creator.htm.
Please make sure that you restart your Qt creator after you copied your prf file and do a clean/rebuild of your project.
Let me know if you have more questions.
Regards,
