Pythonwin does not open in Windows 8.1
13199
6
01-18-2014 04:53 PM
MarkMcPherson1
No matter what I do, Pythonw.exe (from Arcmap) does not open. I am using Windows 8.1.
Does anyone know what to do?
V_StuartFoote
Mark,
The Python non-console script interpreter pythonw.exe, is not the PythonWin IDE ( http://sourceforge.net/projects/pywin32/files/pywin32/Build%20218/ )
ArcGIS no longer ships the PythonWIn IDE and its pyWin32 based GUI.  Your default ArcGIS 10.1 or 10.2 install will have only the native Python GUI--IDLE, or Esri's Python console in ArcMap.
If you'd like to use the PythonWin IDE current build is 218 and you'll want the Python 2.7 specific build, pywin32-218.win32-py2.7.exe
Of course this is all a bit shaky on Windows 8.1 where you will need to install ArcGIS 10.1 or 10.2 with compatibility settings, although ArcGIS 10.2.1 seems to be stable.
Stuart
MarkMcPherson1
Thank you for that. Well, I downloaded the file you recommended, but it looks like it just copied what I already have (I have 10.2 ArcInfo). I see the file Pythonw.exe, but nothing happens when I click on it.
I changed the Compatibility setting to "Windows 7", and even "Run as Administrator", but nothing happens.
This Windows 8.1 has just been a nightmare. Does this program work for you?
V_StuartFoote
The pythonw.exe program is not a GUI program. It is used in scripting a Python program that requires no console window for user input or review.
For both the Python IDLE IDE GUI and the PythonWin IDE GUI, with Windows 8 or 8.1 you have to launch the program from the metro search panel (the Magnifying glass).
Or, you can add a "Programs" toolbar to the task bar to mimic what you were used to through the Windows 7 releases.
You can follow one of these guides:
[INDENT]Short and sweet...
http://blog.laptopmag.com/how-to-add-an-all-programs-button-to-the-windows-8-taskbar
More technically complete...
http://www.eightforums.com/tutorials/2460-start-menu-toolbar-create-windows-8-taskbar.html
[/INDENT]
Point is with this Start Menu -> Programs restored, you'll have the familiar clickable icon to open either IDE with.
Luke_Pinner
MVP Regular Contributor
Just to reiterate, pythonw.exe is not the PythonWin executable. That is located at <python install dir>\Lib\site-packages\pythonwin\Pythonwin.exe (i.e. for 10.1 it is C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\Pythonwin.exe).
MarkMcPherson1
Okay, I got it, now. I appreciate everybody's help.
MarkMcPherson1
Okay, I got it now. So, I downloaded the zip file from sourceforge.net, as you indicated. I now realize that this is installed "on top of" the existing Python that come with ArcMap 10.2. Then, I went to C:\Python27\ArcGIS10.2\Lib\site-packages\pythonwin\Pythonwin.exe and can now run the program. YAY!
Thanks everybody for your help.
Mark
Mark,
The Python non-console script interpreter pythonw.exe, is not the PythonWin IDE ( http://sourceforge.net/projects/pywin32/files/pywin32/Build 218/ )
Stuart
