Data Driven Pages and Key Numbering
954
01-10-2014 09:54 AM
WightmanAdmin
Hello all-
My problem is two-fold.
I am making a mapbook for a client and am struggling putting it together in the most efficient manner.  I have a transmission line and parcels that intersect it along the way in my MXD.  I have already created an index polygon to use for data driven pages, but I am struggling with the labeling of the parcels.  My client wants each page to key number the parcels instead of labeling them individually on the map.
Each page has a polygon (which is the data driven pages index).  There are also parcels located within these polygons.  I need to find a way to spatially join the parcel attributes to the associated polygon that it is within.  I do realize this is a many-to-one relationship and cannot be done with a normal spatial join.  Does anyone know of a way to accomplish this?
Also, I want to only label the parcels that have their centroid located in the index of each sheet.  For example, parcels a, b, c, and d are located on page 22 (within the index polygon for page 22).  I only want to label those parcels and not the surrounding ones.  The catch is that I need them to be key numbered in a specific format (below).
      Easement          Owner Name          Deed
a
b
c
d
If I can join the parcel attributes to each index polygon I think I can accomplish this with dynamic text and maybe a definition query?
Thank you in advance!!!
MattSayler
I'm not sure I understand that bit. Instead of labeling the parcels on the map, are you talking about listing them somewhere on the page or on a separate page, sort of like a road atlas does for streets?
Are the parcels only ever in one of the index polygons, or is there overlap?
WightmanAdmin
Instead of labeling the parcel within the polygon itself, they want me to label each with a number and list them on the page in list of sorts.
A few of the parcels are in multiple index polygons.
After a little more research, I guess I am trying to insert a dynamic table to work with the DDP.
Thank you!
