Geocoding Error
1256
12-24-2013 05:11 AM
SharonHeller
Trying to use the World Geocode Service to geocode addresses from a table. No matter what I do, I get an error that says "There was an error trying to process this table"
Fields are very simple "Address" "City" "State" "Postal" "Country"
NidhinKarthikeyan
Honored Contributor
The issue might be specific to a particular field. Check the field names and avoid spaces, special characters/invalid record or data type. Also mention the exact version of ArcGIS Desktop and Service Pack(If any). There is a bug found in 10.0 SP2.
If the issue is not data specific, applying Geocoding General Maintenance Patch might help you.
BradNiemand
What version of ArcGIS are you using?
Brad
GuyKouwoaye
I am using ArcGIS 10
BradNiemand
Does the geocoding process fail right away or does it process for some time before failing?
Brad
