python label expression does not filter labels
1118
12-19-2013 05:49 AM
SWCASWCA
I have a taxlot layer with a numeric (double) field called GIS_ACRES. I only want to label those features that are greater than 1 acre in size. I am using this expression:
def FindLabel ( [GIS_ACRES], [TLID]  ):   if ( [GIS_ACRES]  > 1 ):     return [TLID][-5:]   else:     return ""
also tried if ( [GIS_ACRES] ) > 1:
makes no difference.
It labels ALL taxlots, regardless of size. Why doesn't it work? What syntax am I missing? I get no errors, just doesn't filter.
I recently installed 10.2 over 10.1. Should I also have updated something related to Python?
JoshuaChisholm
Hello SWCA,
It seems like python isn't recognizing your [GIS_ACRES] field as a double field (or even as a number). To get around this you can convert it to a float. It's also probably a good idea to compare it to another float (1.0 instead of 1).
def FindLabel ( [GIS_ACRES], [TLID]  ):   if ( float([GIS_ACRES])  > 1.0 ):     return [TLID][-5:]   else:     return ""
Let me know how it goes,
Good luck!
JoshuaChisholm
Hello SWCA,
Good luck!
SWCASWCA
That worked great! Thanks!
