CurrentDate = "20130625" OutName = "tempgdb.gdb" InSpreadsheet = "G:\Documents\GIS\HydstraData\HydstraMeasurementsDeep\HydstraMeasurements_" + CurrentDate + ".XLS" arcpy.ExcelToTable_conversion(InSpreadsheet,OutName)
Solved! Go to Solution.
# Set the workspace. env.workspace = "G:\Documents\GIS\HydstraData" arcpy.env.overwriteOutput = True ## Set the Spatial Reference. Spatial_Reference = "PROJCS['NAD_1983_California_Teale_Albers',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Albers'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',-4000000.0],PARAMETER['Central_Meridian',-120.0],PARAMETER['Standard_Parallel_1',34.0],PARAMETER['Standard_Parallel_2',40.5],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]" OutFolderPath = env.workspace OutName = "tempgdb.gdb" ##Check if geodatabase exists. if arcpy.Exists(OutName): ##Delete geodatabase. arcpy.Delete_management(OutName) ##Create geodatabase. arcpy.CreateFileGDB_management(OutFolderPath,OutName) DateStart = date(2013,6,25) DateEnd = date(2013,6,26) for dt in rrule(DAILY, dtstart=DateStart, until=DateEnd): CurrentDate = dt.strftime("%Y%m%d") print CurrentDate ##Create Point Shapefile from spreadsheet. InSpreadsheet = "G:\Documents\GIS\HydstraData\HydstraMeasurementsDeep\HydstraMeasurements_" + CurrentDate + ".XLS" X_Coords = "Longitude" Y_Coords = "Latitude" Z_Coords = "MeanData" Out_Layer = "Data_" + CurrentDate OutTableName = os.path.join(OutFolderPath,OutName,"Data_" + CurrentDate) print OutTableName arcpy.ExcelToTable_conversion(InSpreadsheet,OutTableName) print "Completed."
