python code for "export map"
964
12-09-2013 02:25 AM
ElaineKuo
Dear all,
System: Windows Vista
ArcGIS 9.3 Workstation
Python 2.5
I want to know any python code for ???Export Map??? (under file tab) to TIF in ArcMap.
I want to save time for doing it for 100 shape files.
Thank you.
Elaine
JoshuaChisholm
Hello Elaine,
I'm not sure if this will work in 9.3, but this script works for me (10.1).
The script will zoom to the given layers (using the targetLayers variable) then export them to TIF files.
import arcpy
mxd=arcpy.mapping.MapDocument("C:\\Path\\To\\Your\\Map.mxd") #path to your MXD
targetLayers=["Alberta","Ontario","Nova Scotia"] #Layer names as they appear in TOC
df=arcpy.mapping.ListDataFrames(mxd)[0] #if you are not using the first dataframe in the MXD, change '0' to the 0-based index of whichever dataframe use wish to use
allLayers=arcpy.mapping.ListLayers(df)
for targetLayer in targetLayers:
    for lyr in allLayers:
        if targetLayer==lyr.name:
            #Zoom to layer:
            ext=lyr.getExtent()
            df.extent=ext
            #Export TIF:
            arcpy.mapping.ExportToTIFF(mxd, "C:\\Path\\To\\TIFs\\"+targetLayer+".tif") #path to desired location and filename of TIF file
del mxd
del allLayers
del lyr #this line will error if you supply an empty MXD
print "Completed Successfully!"
Let me know if it gives you any trouble or you need anything different.
Good luck!!
~Josh
TimBarnes
Arcpy.Mapping was only introduced at version 10.? so it wont work under the older geoprocessor. I think that before arcpy.mapping was around you needed to do it in a VBA macro- Perhaps the old arcscripts may have something?
