Encrypt password for idp properties...
1758
7
12-04-2013 12:11 PM
ZachChristoff
New Contributor III
"While entering the credentials of the account, you must enter the plain text password of the account. When Portal service is restarted, it will encrypt the password and store it in this file."
I've tried this about 10 times... I can't seem to get it to encrypt the password.
Anyone else have any luck with this?
RaviNarayanan
In the example shown above, idp.type seems incorrect.it should be WINDOWS instead of WINDOW.
idp.type=WINDOWS
RaviNarayanan
Is the value of dp.userpassword.encrypted set to false before restarting the portal?
After updating the username/password, please make sure idp.userpassword.encrypted=false. After restarting portal will encrypt the password and change this value to true.
http://resources.arcgis.com/en/help/main/10.2/index.html#//017s00000066000000
ZachChristoff
New Contributor III
# 2. WINDOWS
idp.type=WINDOW
idp.ad.user=mydomain\\myusername
idp.ad.userpassword=mypassword
idp.ad.user.fullnameattribute=cn
idp.ad.user.emailattribute=mail
This is my current portal-config.properties setup.
I stop & started the Portal for ArcGIS services and nothing happened.
JacobBoyle
Occasional Contributor III
make sure you actually close the config file before you restart, for some reason, that was the only way I could get portal to re-read the file.
ZachChristoff
New Contributor III
No luck... I saw the timestamp get updated on the portal-config file, but still no encryption applied.
RaviNarayanan
idp.type=WINDOWS
ZachChristoff
New Contributor III
@ravi
That did the trick. Thank you!
WilliamCraft
MVP Regular Contributor
Please mark the correct answer and vote up helpful replies.
