ArcScene - Batch base heights?
513
11-30-2013 01:54 PM
BlakeCaldwell
I am working on a project for a DEM class, in which we digitized an orthophoto of our choice, created a 3d environment in ArcScene,  and floated the scene over a DEM.
My question is: is it possible to do some sort of batch operation to float all the shapefiles over my DEM?  It seems tedious to have to go "properties > base heights > floating on custom surface > select dem" for each shapefile.  I know a bit of Python, but I couldn't find anything in ESRI Help that indicated the syntax needed for base height operations.  Or maybe it would be possible to combine all my shapefiles (similar to a raster mosaic???) so I could then float the combination over my DEM?
Any help would be appreciated, even if it is to say the only way is to manually do each shapefile!
SharonSheehan
Did anyone find a solution to this question?
