Need help adding a WMTSLayer from service.
7126
7
11-28-2013 03:13 PM
JulieTeal
Hi guys.
I may be way off base here but I'm trying to add a layer from a WMTS connection. I'm using the .Net SDK (C#).
So far  I can connect to the Server using IWMTSConnection and then create a WMTSLayer with WMTSConnection() but I can only ever use the first WMTSLayer as an ILayer. I can iterate over the whole structure and pull layer descriptions using IWMTSServiceDescription with IWMTSLayerDescription. But Im at a loss creating a connection where I can use a specific LayerName/Identifier.
Is there a way to either specify the LayerName perhaps when creating the IWMTSConnection or creating the WMTSLayer, that will allow me access other WMTSLayers?
Heres a cut down version of what I currently have:
    IWMTSLayer wmtsLayer = new WMTSLayerClass();
    IDataLayer dLayer = new WMTSLayerClass();
    IPropertySet propSet = new PropertySetClass();
    propSet.SetProperty("URL", "http://localhost/erdas-iws/ogc/wmts/?Service=WMTS&Request=GetCapabilities");
    IWMTSConnectionFactory wmtsConnFactory = new WMTSConnectionFactoryClass();
    IWMTSConnection wmtsConnection = wmtsConnFactory.Open(propSet, 0, null);
    ESRI.ArcGIS.GISClient.IWMTSServiceDescription wmtsServiceDescription = wmtsConnection as IWMTSServiceDescription;
    wmtsLayer.WMTSConnection(wmtsConnection);
    for (int i = 0; i < wmtsServiceDescription.LayerDescriptionCount; i++)
          IWMTSLayerDescription layerDescription = wmtsServiceDescription.get_LayerDescription(i);
          if (layerDescription.Identifier.Equals(Wmts_Name, StringComparison.InvariantCultureIgnoreCase))
               //We have a match
               //Maybe need something here to open the correct WMTSLayer?
     if (wmtsLayer != null)
          IMxDocument mxDocument = (IMxDocument)mxApp.Document;
          mxDocument.FocusMap.AddLayer((ILayer)wmtsLayer);
          return true;
Any help on this is greatly appreciate.
Thanks.
ShamusFuller
It does not seem like it should be rocket surgery to add a WMTS layer into a layer or layer group. Be that as it may, I can find no working c# example or reference to anyone that has successfully accomplished such a feat. Has anyone done this? Can it be done? How? I have successfully displayed a single layer from a WMTS service, but the other layers would be nice to have too. I can't even find a UID for a WMTS layer.
Seems oddly quiet, would appreciate someone who knows speaking up.
JulieTeal
I guess the lack of response on this means it isn't possible. Seems strange that WMTS is implemented but is not usable.
JimRaynor
I reviewed your code and corrected it like below:
public static ILayer GetWMTSLayer(string url = "http://IP-Address:Port/Service/rest/services/OSM/MapServer/WMTS")
            propSet.SetProperty("URL", url);
            try
                var con = wmtsLayer.Connect(wmtsConnection.FullName);
                //ESRI.ArcGIS.GISClient.IWMTSServiceDescription wmtsServiceDescription = wmtsConnection as IWMTSServiceDescription;
                //string layerName = "GoogleMapsRoad",
                //for (int i = 0; i < wmtsServiceDescription.LayerDescriptionCount; i++)
                //      IWMTSLayerDescription layerDescription = wmtsServiceDescription.get_LayerDescription(i);
                //      if (layerDescription.Identifier.Equals(layerName, StringComparison.InvariantCultureIgnoreCase))
                //           //We have a match
                //           //Maybe need something here to open the correct WMTSLayer?
                if (con)
                    return (ILayer)wmtsLayer;
            catch (COMException ex)
                MessageBox.Show("Couldn't Get the service:" + url);
            catch (Exception ex)
            return null;
JulieTeal
Thanks for your reply but I was already at a point where I could connect to a WMTS service and add a layer. The issue here is retrieving anything other than the first layer.
TomSchuller
Hy,
I have the same problem:
  I need to get a specific sublayer of a WMTS-mapservice.
  I'm also getting listed all the sublayers in the IWMTSLayerDescription but can't return a single sublayer as ILayer.
  I'm also always getting the first sublayer from the list returned as ILayer.
Any solution or workaround?
Tom
NitinKandpal1
I am facing similar problem. I want to add all the layers in my WMTS service to ArcMap, but I am able to get only one. Has someone got any solution for this.
Regards
Nitin Kandpal
NitinKandpal1
I got solution for adding all layers at ones, as well as a particular layer to ArcMap:
public static void GetWMTSLayer(string url = "http://IP-Address:Port/Service/rest/services/OSM/MapServer/WMTS")
     IProperySet propSet= new PropertySetClass();
     propSet.SetProperty("URL",url);
     IWMTSConnectionFactory wmtsConnFactory=new WMTSConnectionFactoryClass();
     IWMTSConnection wmtsConnection=wmtsConnFactory.Open(propSet,0,null);
     IWMTSServiceDescription wmtsServceDescriotion=wmtsConnection as IWMTSServiceDescription ;
     for(int i=0;i< wmtsServceDescriotion.LayerDescriptionCount;i++)
          IWMTSLayerDescription layerDescription=wmtsServceDescriotion.getLayerDescription(i);
          IWMTSLayer wmtsLayer=new WMTSLayerClass();
          IPropertySet propSet_1=new PropertySetClass();
          propSet_1.SetProperty("URL", url);
          propSet_1.SetProperty("LayerName",layerDescription.Identifier);
          WMTSConnectionName connectonName= new WMTSConnectionNameClass();
          connectionName.ConnectionProperties=propSet_1;
          wmtsLayer.Connect((IName)connectionName);
            addData(wmtslayer);
public static void addData(IWMTSLayer wmtslayer)
     IMap pMap=(IMap)((IMxDocument)ArcMap.Application.Document).FocusMap);
     ILayer pLayer=new FeatureLayer();
     pLayer=(ILayer)wmtslayer;
     pMap.AddLayer(pLayer);
