programmatically add feature class to feature dataset
5698
11-26-2013 12:26 AM
Rvan_Rijen
We are using ArcGIS 10.0.
We have several existing feature classes that we want to add to a feature dataset. Of course you can drag and drop the feature classes in the dataset, but our requirements dictate that all changes must be scripted.
Is it possible to use a toolbox to move a feature class into a feature dataset?
I have tried arcpy.Rename_management(r'feature_class', r'feature_dataset\feature_class'). This does not give an error and returns the text <Result 'feature_dataset\feature_class'>, but nothing actually happens. Looks like a bug to me...
Thanks!
Rob
JakeSkinner
Esri Esteemed Contributor
Hi Rob,
I don't believe this will be possible using Python.  You will most likely need to do this using one of the data transfer methods with ArcObjects:
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//0001000003rp000000
JakeSkinner
You can import the feature class to the feature dataset as a new name, delete the original feature class, and then rename the feature class in the feature dataset.  Ex:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\redlands.gdb"
fc = "Hospitals"
dataset = "test"
arcpy.FeatureClassToFeatureClass_conversion(fc, env.workspace + "\\" + dataset, fc + "_1")
arcpy.Delete_management(fc)
arcpy.Rename_management(fc + "_1", fc)
Rvan_Rijen
Thanks for your reply Jake!
These feature classes are in an Oracle database and are >25GB in size. Creating a physical copy of the data and would take a lot of space and time.
In my understanding, a feature dataset is merely logical layer in the SDE administration. When we use ArcCatalog to move a feature class into a dataset, the actual Oracle tables are not affected. Only the SDE administration (e.g. gdb_items, gdb_itemrelationships) is changed.
Is it possible to duplicate this ArcCatalog behaviour in Python?
Rob
JakeSkinner
Hi Rob,
Rvan_Rijen
Thanks Jake!
I'll look into the data transfer methods.
Rob
