Migrating VBA Function to vb.net
3598
9
11-24-2013 10:09 AM
HushamHassan
I am facing problem migrating this function from VBA  to vb.net.  I do appreciate  your help. I am using 10.1 and vs2010
Public Function GenerateClassBreaks(pFeatLayer As IFeatureLayer, sValFieldName As String, lNClass As Long, sClassification As String) As Variant
    ' classifies data using IClassify2 and Quantile classification,
    ' then creates ClassBreaksRenderer using these breaks,
    ' and assigns to first layer in the map
    On Error GoTo ErrorHandler
    Dim pFClass As IFeatureClass
    Dim pFeature As IFeature
    Dim pFCursor As IFeatureCursor
    Dim pTable As ITable
    Dim pClassifyGEN As IClassifyGEN
    Dim pTableHistogram As ITableHistogram
    Dim pHistogram As IHistogram
    Dim frqs As Variant, xVals As Variant
    Dim i As Integer
    Set pFClass = pFeatLayer.FeatureClass
    Set pFCursor = pFClass.Search(Nothing, False)
    Set pFeature = pFCursor.NextFeature
    Set pTable = pFClass
    'Set pClassifyGEN = New Quantile
    Select Case sClassification
        Case "Equal Interval"
            Set pClassifyGEN = New EqualInterval
        Case "Natual Breaks"
            Set pClassifyGEN = New NaturalBreaks
        Case "Quantile"
        Case "Standard Deviation"
            Set pClassifyGEN = New StandardDeviation
    End Select
    'Set pClassifyGEN = New EqualInterval
    Set pTableHistogram = New TableHistogram
    Set pHistogram = pTableHistogram
    pTableHistogram.Field = sValFieldName
    ' matches renderer field
    Set pTableHistogram.Table = pTable
    pHistogram.GetHistogram xVals, frqs
    pClassifyGEN.Classify xVals, frqs, lNClass
    ' use "iNClass" number of classes
    GenerateClassBreaks = pClassifyGEN.ClassBreaks
    GoTo Endproc
ErrorHandler:
    MsgBox Err.Description, vbInformation, "GenerateClassBreaks"
Endproc:
    Set pFClass = Nothing
    Set pFeature = Nothing
    Set pFCursor = Nothing
    Set pTable = Nothing
    Set pClassifyGEN = Nothing
    Set pTableHistogram = Nothing
    Set pHistogram = Nothing
End Function
Regards
AlexanderGray
Honored Contributor
Perhaps you could describe your problem.
BruceNielsen
A couple of hints:
  1. You no longer need to use the 'Set' keyword
  2. You can combine the 'Dim' and 'Set' statements on one line
  3. Dim pFClass As IFeatureClass
    can now be expressed as
    Dim pFClass As IFeatureClass = pFeatLayer.FeatureClass
  4. Use a Try statement to trap errors. You can see the errors with ex.ToString
HushamHassan
agray1, bruce.nielsen
Thank you,  here is my VB.net  code..
Public Function GenerateClassBreaks(pFeatLayer As IFeatureLayer, sValFieldName As String, lNClass As Integer, sClassification As String) As Object
        Try
            Dim frqs, xVals As Object
            Dim i As Integer
            pTable = pFClass
                    pClassifyGEN = New EqualInterval()
                    pClassifyGEN = New NaturalBreaks()
                Case "Quantile"
                    pClassifyGEN = New Quantile()
                    pClassifyGEN = New StandardDeviation()
            End Select
            pTableHistogram = New TableHistogram()
            pHistogram.GetHistogram(xVals, frqs)
            pClassifyGEN.Classify(xVals, frqs, lNClass)
        Catch ex As Exception
            MessageBox.Show(Information.Err().Description, "GenerateClassBreaks", MessageBoxButtons.OK, MessageBoxIcon.Information)
        End Try
    End Function
but still the function  doesn't return a value.
Regards
AlexanderGray
Honored Contributor
not sure this is the problem but, "GenerateClassBreaks = pClassifyGEN.ClassBreaks" should be:
"return pClassifyGEN.ClassBreaks"
HushamHassan
agray1
Thank you for your help...  that not work..  the error maybe on this line of code..
I replaced the variant with object, since there is no variant on .net
Regards
AlexanderGray
Honored Contributor
object is a lot like variant, that should be ok.  It's not really a best practice to return an weak type in a method but not wrong.  If you assign pClassifyGEN.ClassBreaks to a variable before returning it, can you check if it has a value?
HushamHassan
Hi agray1
Thank you  and sorry for delay response,  I did assign pClassifyGEN.ClassBreaks to a variable before returning it, but it has no value..
and for the same function I am getting  casting error "unable to cast object of type System.double to type system.int32"
Many thanks and Regards
AlexanderGray
Honored Contributor
The function returns an array of doubles.  If you do something like this do you get an array?
dim breaks() as double =  pClassifyGEN. pClassifyGEN.ClassBreaks
HushamHassan
hi,
Really apprciate your help.. still  I am getting Null funciton,    I did some casting  as follow
Dim dataFrequency As Object = Nothing
            Dim dataValues As Object = Nothing
            Dim frqs As Integer() = TryCast(dataFrequency, Integer())
            Dim xVals As Double() = TryCast(dataValues, Double())
I am getting values for most of the variables,  but still the function return Null
Regards
