Is ArcGIS API for JavaScript 3.7  compatible with ArcGIS server 10.0 ?
4286
5
11-20-2013 09:13 PM
ggdd
I'm new to ArcGIS server. Since ArcGIS server 10.0 was published 2 years ago, while the Javascript API 3.7 is released just now. I'm not sure if they are compatible with each other.
Any help?
DeepikaJain
Hi
I guess the Javascript API 3.7 is for ArcGIS Server 10.1.
Please refer the below link.
https://developers.arcgis.com/en/javascript/jshelp/ags_overview.html . Click on the links mentioned for ArcGIS Services, they direct you to ArcGIS Server 10.1
Deepika
ggdd
I also guess 10.1 is work, but the new staff can not be installed on my x86 OS.
So, I have to back to 10.0 ...
JohnathanBarclay
I am using JS API 3.7 with ArcGIS Server 10.0 without much trouble.
There are only a few features in the API that I have come across that require 10.1.
BjornSvensson
Esri Alum
In general, any version of the Javascript API will work with any ArcGIS Server 9.3 or later.
Though certain functionality requires a newer server version, most things will work just fine.
JeffPace
we are currently using 3.7 with 10sp5 without issue
