Quick Import KMZ to output error
2961
11-19-2013 05:21 AM
AndrewL
Hello. I am trying to convert a KMZ file downloaded from the NWS to a feature class or shapefile using the DI extention.
I am getting this error however "error when writing schema: a unique destination feature type name could not be generated for"
Does this have to do with the actual data being corrupt or am I missing something?
I also tried the KML to layer Conversion tool and get "ERROR 000401: No features were found for processing
Failed to execute (KMLToLayer)."
I have viewed the KMZ file in Google Earth and it looks fine. Thank you.
BugPie
Any solution to this? I am having a similar experience with the quick import.
IanMurray
Honored Contributor
Hi Collin,
Please check this thread.
KML to Layer Issues
If that doesn't help, can you post your KMZ file?
