Export Raster Data Tool
1179
11-08-2013 11:25 AM
PaulVanDyke
Is there a way to batch export rasters with 4 bands to rasters with 3 bands?
I am able to add each raster to my ArcMap session and export them one at a time by right-clicking and choosing Data, Export Data... and then choosing "Use Renderer" in the resulting dialog box.
I have a bunch or 4-band (R,G,B,NIR) imagery and I'm trying to convert them to R,G,B for additional processing in another software program.
If there's a better way, I'm all ears!
Paul
larryzhang1
Paul,
For 'Batch' export (conditionally), I share the same idea to request ArcGIS 10.x having this capability as sooner as possible. Pls refer to the post at http://forums.arcgis.com/threads/85826-Exporting-rasters-as-a-batch-in-ArcMap?p=303823&viewfull=1#po...
For specific band(s) export, for sure you can. The easy solution is:
Step 1: create/load into MD;
Step 2: use the function called 'Extract Bands' in the chain for 321;
Step 3: export individually as same procedure as you done.
For image processing in operation (dealing with massive multispectral rasters and /or panchromatic) , personally, it is still challenging for ArcGIS 10.x to 'effectively' do those tasks to meet high-level needs, including rectification (with/without GCP), pansharpening, and color-correction among rasters overall......
[INDENT]Pls refer to http://forums.arcgis.com/threads/27928-Collecting-amp-combining-GCP-during-creation-of-Mosaic-Datase... and http://forums.arcgis.com/threads/19911-How-to-create-image-service-that-can-be-pansharpened?p=65043&...[/INDENT]
