FeatureUpdater Output / delete old features / hourly instead of minutely?
3125
11-05-2013 10:00 PM
ChristianStern
Hi all,
I am using the GeoeventProcessor's feature updater output to add new features to a server layer. This works all fine. However, I want  to delete "old" features (older than one minute) regularly. There is an option (advanced) for setting the "Maximum Feature Age (Minutes)". I have set this to 1, but the features in my database get deleted if they are older than one hour only. Is this a bug? Or what am I doing wrong?
The database uses the database system time (CET) for the timestamp.
Hope you can help, thanks,
Christian
ChristianStern
I found it out by myself. The problem was that I used the database system time as timestamp. Once I changed it to UTC it worked.
Christian
