flip selected line using python stand-alone window
911
5
11-02-2013 08:58 AM
HollyZhang1
I am trying to flip selected pipelines using stand-alone python window. Below are the steps I used:
   1). line join attributes from other tables (MakeFeatureLayer, AddJoin);
   2). select lines based on the joined attributes (SelectLayerByAttribute);
   3). remove joins (RemoveJoin);
   4). flip line on the selected lines (FlipLine_edit with or without MakeFeatureLayer after the selection).
It is shown the same error:
ERROR 999999: Error executing function.
Workspace or data source is read only.
Failed to execute (FlipLine).
Anyone has any solution?
Thanks.
RichardFairhurst
Thanks.
Can you post your actual script?  What is the line data source?  Is it SDE?  Is it a geometric network?  What license level do you have?  How many features are you trying to flip at one time?  I found it crashes if I try to flip too many at one time (more than about 10,000).  Did you use code like this for the flipline section?
import arcpy
try:
    arcpy.FlipLine_edit(inFeatures)
except Exception, e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print "Line %i" % tb.tb_lineno
    print e.message
HollyZhang1
I am using the testing data in a file deodatabase. It is not a geometric network. The features are about 2000 to flip at one time. I use code exactly like this.
RichardFairhurst
Is the fc open in a  map?  Have you tried editing manually?  Are you sure you have access to the workspace you used?  Post your method of getting the fc into your code.
HollyZhang1
It does work good in ArcMap. I tried several times running the stand-alone python. They were all failure. Very lucky, I just got this time successful. Thanks.
DarrenMcCormick
Holly:
In a Python script I can't seem to get FlipLine_edit to work on a selected set of lines contained within a shapefile. Unfortunately, all of the lines are getting flipped instead of just those that are selected.
Did you get FlipLine_edit to work through a Python script on a selected line or set of selected lines? If you were successful with this, could you post (with code) what you did?
Thanks!
