Insert Cursor to Table In Memory
8504
11
10-31-2013 12:10 PM
ClintonCooper1
I am trying to take a large dataset and import (export or append) it into an "in memory" table where I can then run the calculations:  I need to import three fields ( SOS_VOTERID, FEAT_SEQ and YEAR_Of_BIRTH).  For my code below, I am just working with 2.  I believe I need to run a search cursor on my orig table, and then run an insert cursor to import the data into my new table.  I am running into an error that says:
Runtime error  Traceback (most recent call last):   File "<string>", line 23, in <module> TypeError: sequence size must match size of the row
import arcpy, collections  from arcpy import env env.workspace = r"C:\Users\cc1\Desktop\NEW.gdb\WAYNE" table = "WAYNE"  table2 = arcpy.CreateTable_management("in_memory", "WAYNE") arcpy.AddField_management(table2, "SOS_VOTERID","TEXT", field_length=25) arcpy.AddField_management(table2, "FEAT_SEQ","LONG")  newList = {row[0]: row[1] for row in arcpy.da.SearchCursor(table, ["SOS_VOTERID","FEAT_SEQ"])}                                         tbl = arcpy.ListTables("*")                       for table in tbl:     fieldList = arcpy.ListFields(table)     for field in fieldList:         newList.append([table,field.name])    #  this populates the new list with table and field to directly insert to new table with arcpy.da.InsertCursor(table2, ['SOS_VOTERID', 'FEAT_SEQ']) as insert:     for f in newList:                                          insert.insertRow(f) del insert
Anyone know where I am going wrong?  Thanks!
Clinton
ChrisSnyder
Honored Contributor
It'd look something like this I think - see how for each loop of the search cursor, the data (the searchRow tuple) gets fed dirtectly to the insertRow?
import arcpy inputTbl = r"C:\Users\cc1\Desktop\NEW.gdb\WAYNE" outputTbl = str(arcpy.CreateTable_management("in_memory", "WAYNE").getOutput(0)) arcpy.AddField_management(outputTbl, "SOS_VOTERID","TEXT", field_length=25) arcpy.AddField_management(outputTbl, "FEAT_SEQ","LONG") insertRows = arcpy.da.InsertCursor(outputTbl, ["SOS_VOTERID","FEAT_SEQ"]) searchRows = arcpy.da.SearchCursor(inputTbl, ["SOS_VOTERID","FEAT_SEQ"]) for searchRow in searchRows:     insertRows.insertRow(searchRow) del searchRow, searchRows, insertRows
ChrisSnyder
Honored Contributor
I think you would probably want some code that looked more like this:
http://forums.arcgis.com/threads/66434-A-better-way-to-run-large-Append-Merge-jobs?p=230850&viewfull...
No need to store the data in a list or dictionary. Just read it via the search cursor and then write it directly to the in_memory table.
Nice dictionary comprehension BTW! Forgot that was supported now in v2.7... I learned something today.
ClintonCooper1
I kind of understand where you are coming from, but not fully.  I am having issues as to where I put the line:
at within the code.  Could you give a little bit more explanation of how to write this code?  Thanks!!
ChrisSnyder
Honored Contributor
ClintonCooper1
import arcpy
Thank you so much!  This worked great!
I do have one more question.  To get the benefits from in memory performance, once I create a table in memory, will all the subsequent calculations/operations done on that table be in memory as well or do I need to continue to call the in memory operation?  Thanks!
by Anonymous User
Not applicable
That is a nice trick.
ClintonCooper1
I still have this one last question. To get the benefits from in memory performance, once I create a table in memory, will all the subsequent calculations/operations done on that table be in memory as well or do I need to continue to call the in memory operation? Thanks!
ChrisSnyder
Honored Contributor
It depends...
Some operations (such as AddField or CalculateField) can operate directly on the in_memory table. Other operations (such as Frequency or SummaryStatistics) create a new output table that, depending on your specifications, may be written to either the in_memory workspace or to disk.
That said, reading input from in_memory and then writting the output to in_memory would of course be the fastest option you have. Only worry is if you have enough available RAM to complete the process(es)...
ClintonCooper1
I have plenty of memory, but I am not seeing any increase in performance 😞  My workflow consists of creating a new table in memory, adding the fields and indexes, appending the data in, and then performing about 7 field calculations using data cursors.  I have runt he process both in memory and regular, and they are both running at around 23 hours to complete.  I have seen that once your dataset gets a to a certain size, you lose your in memory performance gains.  I guess that I am seeing that with my data set.  Thanks for all your help!
Clinton
JamesCrandall
Clinton
This may or may not help (maybe just confuse the approach), but I wanted to mention that the in_memory is definitely a performance gainer as long as the RAM is available.  The other performance gain is achieved by performing the tabular operations on non-ESRI specific objects.
So, we heavily use Pandas Data Frame objects to join/merge tabular data as well as populate new fields with math/statistic operations.  We simply convert back and forth between esri and pandas objects using NumPyArrayTo..FeatureClass/Table and FeatureClass/Table..ToNumpyArray
Just something to think about as it may provide the performance you require.
