Python toolbox default parameter to get updated automatically?
1542
10-31-2013 10:31 AM
ionarawilson1
I have a python toolbox defining the default parameter of a tool based on a value in a combobox created with a python add-in. The code works, but I have to manually refresh the tool everytime I change the values in the combobox. Is there a way for this python toolbox default parameter to get updated without the manual refresh? Thanks
        import Comboboxes_addin
        # the default values
        param2.value = Comboboxes_addin.combobox_1.value
JasonScheirer
Esri Alum
Why don't you do the all of the inputs as parameters in the geoprocessing tool? I'm having trouble understanding why you also need an add-in to pre-fill what are essentially input parameters for a tool.
ionarawilson1
Because I have a bunch of other tools and the user sometimes will not know which tool to use. So these comboboxes would tell him which tool to use through a message box and it would define the parameter defaults based on the choices he already selected on the combobox.
ionarawilson1
Do you have any examples of a python toolbox filtering the list of a second parameter based on the selected item in a first parameter? Thanks
ionarawilson1
I think I got it, I just need to learn how to reference a tool's property inside another tool.
  params = [param0, param1]
        activity = [" "]
        if params[0].value == "Forestry":
            activity = ["SP", "SPR", "MPR"]
        param0.filter.list = ["Forestry", "OW",
                                    "Urban Fire", "ED/PR"]
        param1.filter.list = activity
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        if parameters[0].value == "Forestry":
            parameters[1].filter.list = activity
        return
