Export an attribute table to .txt using arcpy.
14924
10-29-2013 02:22 PM
FredKellner1
This seems like a no-brainer, perhaps I'm missing something. I can easily export tables to .txt format using the the Arcmap interface, but can't do so using arcpy. I have tried the table to table conversion function but this supports every format but a simple .txt file. Is there a work around?
Fred
XanderBakker
Esri Esteemed Contributor
Hi Fred,
You're right that .TXT is not a supported output format in the Table to Table conversion tool. If you work with a featureclass instead of a table the "Export Feature Attribute to ASCII (Spatial Statistics)" would be an option.
If not than you can use the snippet below I found on stack exchange:
http://gis.stackexchange.com/questions/17933/export-table-to-x-y-z-ascii-file-via-arcpy
import arcpy,csv
table =r'c:\path\to\table'
outfile = r'c:\path\to\output\ascii\text\file'
#--first lets make a list of all of the fields in the table
fields = arcpy.ListFields(table)
field_names = [field.name for field in fields]
with open(outfile,'wb') as f:
    w = csv.writer(f)
    #--write all field names to the output file
    w.writerow(field_names)
    #--now we make the search cursor that will iterate through the rows of the table
    for row in arcpy.SearchCursor(table):
        field_vals = [row.getValue(field.name) for field in fields]
        w.writerow(field_vals)
    del row
Please note that things may go wrong with binary (blob) fields and perhaps with Null values as well.
Kind regards,
Xander
FredKellner1
Hi Xander,
Thanks for you input that snippet from GIS stack exchange was just what I needed!
Fred
