Cross-domain issue when scripting ArcGIS server administration
3420
10-21-2013 06:13 AM
YohanBienvenue
I've dealt with cross-domain issues in the past when using the ArcGIS API for Javascript and Flex (Using a proxy.php and the crossdomain.xml respectively), but I'm unsure how to deal with this one.
I created a simple web page so that admin users could easily perform arcgis server task, and I want to use the ArcGIS Server Administrator API to do so from my Javascript in the page.
Here's the typical error message I get at this moment:
XMLHttpRequest cannot load http://azivm2k8sqlexp:6080/arcgis/admin/generateToken. Origin http://192.168.10.18:86 is not allowed by Access-Control-Allow-Origin.
How do I tell the REST API at port 6080 to accept my cross-domain calls?
I'm using ArcGIS Server 10.1
Edit: For now I decided to just add a Proxy rule in my web server's (Apache httpd) configuration that will forward requests appropriately without a cross-domain issue:
ProxyPass /arcgis http://azivm2k8sqlexp:6080/arcgis
ProxyPassReverse /arcgis http://azivm2k8sqlexp:6080/arcgis
and I replaced the URL in my javascript code to point to http://192.168.10.18:86/arcgis/admin instead of http://azivm2k8sqlexp:6080/arcgis/admin. It works, but I dislike this workaround because it would be much simpler for the client to change the ArcGIS server URL (if need be) in the simple config.js file I prepared for them instead of playing with the web server configuration. Will update if I find another solution later. In the meantime, please let me know if there is a simple/better solution then this.
