1) I believe that depends on Oracle settings. the StandardizedQueries recommends that to make it work across all databases.
That is the main idea behind StandardizedQueries, so that the end user does not need to worry about the underlying database's flavor - the end user writes a sql query following StandardizedQueries specs, and ArcGIS Server converts that to an appropriate sql statement conforming to the underlying database's syntax etc.
2) StandardizedQueries syntax doesn't allow to specify dateformat, so you are right, the only option you are left with is to disable StandardizedQueries, if it is absolutely necessary to specify the dateformat in the query.
