merge feature in SDE -arcgis engine C#
4728
10-09-2013 03:05 AM
doxuan_cuong
I have some selected feature as Polygon in SDE geo database show in map control. They are side-by-side features but now I want to merge them into one by code . How can I do this, anyone has any example code ?
I use ArcGIS engine 9.3 and C#
thank you
Cuongdx
tuxedo
code sample :http://gis.stackexchange.com/questions/12154/fastest-way-to-merge-a-feature
It's the best solution to merge polygons in sharpfile but not work with SDE.
Hope this helps
doxuan_cuong
I used to use this code but I can't union 2 adjacent polygons, result return only one polygon (polygon 1 to union ). Two polygons don't intersect , just have a common segment. How can I fix that?
dangxuantien
Hi Mr Cuong,
I am in Viet Nam, maybe this is the same as you.
now, i am researching about arcengine with C# and I have many merge and split polygon.
please help me!
dangxuantien29@gmail.com
