Hello, I just develop an small ArcGIS runtime app, this app initialize a local feature service:var localCenterlineServiceMPK = new LocalFeatureService() { Path = @"C:\Users\XXX\Documents\PackageMap.mpk" }; localCenterlineServiceMPK.StartCompleted += this.StartCompleted; localCenterlineServiceMPK.StartAsync();
then I get a layer for that package (only has one)private void StartCompleted(object sender, AsyncCompletedEventArgs e) { var centerlineLayerService = sender as LocalFeatureService; var centerlineLayer = new ArcGISLocalFeatureLayer { Service = centerlineLayerService, ID = "Routes", LayerName = "routes", Editable = true, AutoSave = true, ReturnM = true }; this._map.Layers.Add(centerlineLayer); }
I create some lines and add it to the layer, the lines appears on the map.then I close the application and proceed to open the file C:\Users\XXX\Documents\PackageMap.mpk using ArcMap, to discover that the features weren't saved. (the package includes the geodatabase).Funny part: I reopen the application....and voila!!!! the features are there.I found that the local server unpacked the contents of the package to : C:\Users\MyUser\AppData\Local\ArcGISRuntime\Documents\ArcGIS\Packages\packagemapin that path resides a copy of the geodatabase, but neither it has the changes in the features.It is driving me crazy!!!!!!! where are the features???
