Find duplicates and give incrementing value
1349
10-08-2013 08:09 AM
RodC
I'm trying to tweak this script to find duplicates in a field and give it a sequential value to it.
As of now the script just auto increments by concatenating the "oldId" field and the "newId" field into the "newId' field.
current output:
123 => 12301
123 => 12302
123 => 12303
234 => 23404
237 => 23705
I would want the desired output to be:
123 => 12301
123 => 12302
123 => 12303
234 => 23401
237 => 23701
so, different id's all get 01 at the end and duplicates get sequential values starting with 01 (using .zfill(2)) to keep the leading zero.
the two fields are also TEXT fields.
any suggestions would be great,
Thanks!
[HTML]
import arcpy
import os
def main():
    workspace = arcpy.GetParameterAsText(0)
    arcpy.env.workspace = workspace
    field = "newId"
    newidfield = arcpy.AddField_management(workspace,'newId','TEXT','','','','','NULLABLE')
    cursor = arcpy.UpdateCursor(workspace)
    for row in cursor:
        row.setValue(field,str(autoIncrement()).zfill(2))
        cursor.updateRow(row)
    new_field = arcpy.CalculateField_management(workspace,"newId","!oldId!"+"!newId!",'PYTHON')
rec = 0
def autoIncrement():
    global rec
    pStart = 1
    pInterval = 1
    if (rec == 0):
        rec = pStart
        return rec
    else:
        rec = rec + pInterval
        return rec
if __name__ == '__main__':
    print "Adding IDs..."
    main()
[/HTML]
DouglasSands
Have you tried using a dictionary? Perhaps something along these lines:
def main():      workspace = arcpy.GetParameterAsText(0)     arcpy.env.workspace = workspace     field = "newId"       newidfield = arcpy.AddField_management(workspace,'newId','TEXT','','','','','NULLABLE')      id_tracking = {}      cursor = arcpy.UpdateCursor(workspace)     for row in cursor:         current_id = row.getValue(field)         if current_id in id_tracking:             count = id_tracking[current_id]             count += 1             row.setValue(field,str(count).zfill(2))             id_tracking[current_id] = count         else:             count = 1             row.setValue(field,str(count).zfill(2))             id_tracking[current_id] = count         cursor.updateRow(row)     new_field = arcpy.CalculateField_management(workspace,"newId","!oldId!"+"!newId!",'PYTHON')
As an added bonus, you don't need the autoIncrement function anymore.
DouglasSands
RodC
def main():
    field = "newId"
    id_tracking = {}
    for row in cursor:
            count += 1
        else:
            count = 1
Awesome this worked!, just added oldid_field = "oldId" and changed current_id = row.getValue(field) to => current_id = row.getValue(oldId_field)
to get those duplicates to increment.
RobertStokes
Hey Rodrigo, where in the code did you place the oldId_field = "oldId"? Can you post your complete code?
Sincerely,
Robert
