Creating a compact cache from from the tiles in an exploded cache
1197
10-01-2013 06:00 AM
OlaSvensson1
Is it possible to create a compact cache from an exploded one actually using the tiles from the old cache?
I have a scenario where I have an exploded cache with tiles I have altered slightly using an image manipulation program. Is it in any way possible to use those tiles when creating a compact cache instead of generating new tiles from the published service?
StevenMoore1
You can use the Convert Map Server Cache Storage Format tool in the Server Tools-->Caching toolbox. I would recommend making a backup of your tiles if possible before converting, as the tool will convert the tiles in place and essentially delete the old version.
http://resources.arcgis.com/en/help/main/10.2/index.html#//005400000012000000
Hope this helps.
OlaSvensson1
Thank you Steve, my first impression was that ArcGIS Server recreated the cache from scratch switching from one format to the other. Now I know that it just put the existing tile png:s into bundles 🙂
