Editor tracking - read configuration
5418
09-26-2013 12:33 AM
DariusBuinovskij2
I'm using Editor tracking. When I'm creating new table I setup it like that:
IClassSchemaEdit4 schemaEdit = ......
schemaEdit.IsTimeInUTC = true;
schemaEdit.EditedAtFieldName = "MODIFICATIONDATE";
The problem is that I need to read those settings somehow. I unable to find how to access that info when I have ITable interface (cast to what?).
I found IEditorTrackingInfo interface. But I unable to find how I can access it from ITable. I found that IDataObjectTable2 has EditorTrackingInfo property, but here again, I need to go from ITable to IDataObjectTable2 somehow.
Also such info exits in IDEEditorTracking interface, but it's for geoprocessing.
Strange that it's not possible to access those properties in easy way - usually new things are available when you cast to some new interface, but it seems no this time. Any help?
BillyBuerger
Just wanted to add that I was looking for this same info.  I want to report out what features classes have edit tracking set and with what values.  It would appear that there is no way to get at this information.  Or at least not a documented way in ArcObjects.  The IDataObjectTable2 interface appears to be coming from ArcServer and sounds like it may have been dropped as of 10.1.  And as mentioned IDEEditorTracking is for geoprocessing.  Why is this not available?  We're given a method to set these values but not read them.  Ug.
AndryJoos
Have you ever found a solution for this? We're currently facing a similar problem.
BillyBuerger
Actually, yes I did.  Unfortunately, it does require using the geoprocessor since ArcObjects still doesn't have a way to read this information.  But using the Geoprocessor and the IDEEditorTracking interface will give you the current edit tracking configuration information.  Here's a snippet that should give you the info on a specific feature class.
Debug.Print("Name, Enabled, CreatedAtFieldName, CreatorFieldName, EditedAtFieldName, EditorFieldName");
string ClassPath = @"D:\Data\Test.gdb\FeatClass";
object DataType = "";
IDataElement DataElement = GP.GetDataElement(ClassPath, ref DataType);
IDEEditorTracking DeEditTrack = (IDEEditorTracking)DataElement;
if (DeEditTrack.EditorTrackingEnabled)
   Debug.Print("{0}, true, {1}, {2}, {3}, {4}", ClassPath, DeEditTrack.CreatedAtFieldName, DeEditTrack.CreatorFieldName, DeEditTrack.EditedAtFieldName, DeEditTrack.EditorFieldName);
else
   Debug.Print("{0}, false", ClassPath);
AndryJoos
Hi William! Thank you for your answer and the snippet! This might work for our case too, and I will try it right away.
