python encoding problem?
1777
09-25-2013 01:27 AM
LiborHladis
Hello, I know that this theme was discussed few times, but I didnt solve the problem using informations that I've found here.
There is (for many of you well known) problem with coding.
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xa0' in position 11: ordinal not in range(128)
I enter ID number (data type string) but the script ends with error.
I have tried .encode('utf-8'), .replace(u'\xa0', ' ') but it was no solution.
First - problematic - part of the script is below:
import arcpy, sys, os, shutil
from arcpy import env
obecJmeno = arcpy.GetParameter(0)
adr_puvodni = u"C:\\vydej2\\mapy_!empty_2013"
adr_nove="C:\\vydej2\\Data_Export\\mapy_"+obecJmeno+"_2013"
vyberZ=arcpy.GetParameter(1)
ID=arcpy.GetParameter(2)
if vyberZ=="obec":
    vyber= "C:\\vydej2\\Data\\CZ020STCE11obc_poly.shp"
    sqlstat= "\"KOD_OBC_TX\"=" + "'" + ID+ "'"
elif vyberZ=="opu":
    vyber= "C:\\vydej2\\Data\\CZ020STCE11opu_poly.shp"
    sqlstat= "\"KOD_OPU_TX\"=" + "'" + ID+ "'"
        etc
Any ideas please?
Btw - this script was fully working yesterday on my collegues computer. Today it doesnt work at his PC as well as at mine.
ArcGIS 10.0 build 4400
curtvprice
You provided no specifics as to how you were getting the parameters - command line, script tool, modelbuilder, etc???
I suggest trying arcpy.GetParameterAsText(), which gives you a string representation instead of an object.
Text is often much easier to work with (for one thing, you can print it out and look at it with repr() -- so you can at least see what you have).
LiborHladis
I tried to use arcpy.GetParameterAsText()  but result is still the same.
From my opinion the problem is in dbf coding (cp1250) because when I have script without parameters and run it in Python shell, it works.
I was getting the parameters using script tool.
I am new in python so maybe I didn't write some important things...
