Problem with where clause and Update Cursor
8572
9
09-20-2013 01:24 PM
DavidDenham
I am working on a script that will allow users to select a project from a pull down list in the tool and then update the status.  I am using an update cursor with a where clause to update the attributes for all of the polygons with the same name.  When I try to run the script I get an error message that the where clause is not a string. Here is the code the where clause is in bold:
# Import arcpy and date time module import arcpy import datetime   # Local variables: today = datetime.date.today() mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers") [0] parcels = arcpy.mapping.ListLayers(mxd, "Parcels", df) [0]   # Geting user input for project name, status, type, submital date and planner name ProjectName = arcpy.GetParameterAsText(0) ProjStatus = arcpy.GetParameterAsText(2) SubmitDate = arcpy.GetParameterAsText(1) DevelopeType = arcpy.GetParameterAsText(3) PlannerName = arcpy.GetParameterAsText(4)   PlanningProjectTracking = "C:\\David Projects\\Planning Project Tracking\\PythonProjectTracking.mdb\\PlanningProjectTracking"   whereClause = "[ProjectName] = '{0}'".format(ProjectName)   #Used update cursor to create update project tracking records. Ucursor = arcpy.da.UpdateCursor(PlanningProjectTracking, whereClause, ["PROJECTNAME","STATUS","SUBMITTALDATE","DEVELOPEMENTTYPE","PLANNER","EDITDATE"]) for row in Ucursor:    row.setValue (ProjectName,ProjStatus,SubmitDate,DevelopeType,PlannerName,today)    Ucursor.updateRow(row) arcpy.RefreshActiveView()
JasonScheirer
Esri Alum
You've mixed up the argument order, the list of fields goes before the where clause. In addition, you're mixing up your cursor models. There's no row.setValue in da.UpdateCursor.
Ucursor = arcpy.da.UpdateCursor(PlanningProjectTracking, ["PROJECTNAME","STATUS","SUBMITTALDATE","DEVELOPEMENTTYPE","PLANNER","EDITDATE"], whereClause) for row in Ucursor:    Ucursor.updateRow([ProjectName,ProjStatus,SubmitDate,DevelopeType,PlannerName,today])
JasonScheirer
Esri Alum
DavidDenham
for row in Ucursor:
Thanks for your suggestion, but I checked the update cursor page on the 10.1 resource center and the syntax that they show is UpdateCursor (dataset, {where_clause}, {spatial_reference}, {fields}, {sort_field}).  I tried to use what you suggested, but it still failed to run with an error message TypeError: updateRow() takes exactly 1 argument (6 given).  I tried to include "",  to hold the place for the spatial reference, but that did not work either.  I will have to see if I can select the features first and then update just the selected features.  This is not the way that I would like to do it since I would like to keep my code as simple as possible.  I
JasonScheirer
Esri Alum
arcpy.da.UpdateCursor and arcpy.UpdateCursor are two different things, your script looks like it's creating an arcpy.da.UpdateCursor but treating it like an arcpy.UpdateCursor. You may be able to get away with your original script just by doing this:
Ucursor = arcpy.UpdateCursor(PlanningProjectTracking, whereClause, ["PROJECTNAME","STATUS","SUBMITTALDATE","DEVELOPEMENTTYPE","PLANNER","EDITDATE"])
DavidDenham
Thanks for the help, but now I am getting an error message AttributeError: Object: Error in parsing arguments for UpdateCurso.  Here is the code that I changed since the last time I posted:
Ucursor = arcpy.UpdateCursor(PlanningProjectTracking, whereClause, "", ["PROJECTNAME","STATUS","SUBMITTALDATE","DEVELOPEMENTTYPE","PLANNER","EDITDATE"])for row in Ucursor:
JasonScheirer
Esri Alum
   for fieldname, value in [('PROJECTNAME', ProjectName), ('STATUS', ProjStatus), ('SUBMITTALDATE', SubmitDate), ('DEVELOPEMENTTYPE', DevelopeType), ('PLANNER', PlannerName), ('EDITDATE', today)]:
       row.setValue(fieldname, value)
DavidDenham
I tried that out and I received a syntax error with:
I thought that the for row in Ucursor: was supposed to be on the next line, but when I tried that I still had an error:
  File "C:\David Projects\Planning Project Tracking\PythonUpdateProjectTracking.py", line 37, in <module>
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\__init__.py", line 1165, in UpdateCursor
    return gp.updateCursor(dataset, where_clause, spatial_reference, fields, sort_fields)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 364, in updateCursor
    self._gp.UpdateCursor(*gp_fixargs(args, True)))
AttributeError: Object: Error in parsing arguments for UpdateCursor
Failed to execute (UpdateProjectTracking).
I don't mind trying to use the selecting by attribute first, but I hate not knowing why this is not working.
JasonScheirer
Esri Alum
The initial arcpy.da solution I provided should have worked if it had been correctly copied. The updateRow() call needs the list of values to be in a [list, like, this].
Either do this:
with arcpy.da.UpdateCursor(PlanningProjectTracking, ["PROJECTNAME","STATUS","SUBMITTALDATE","DEVELOPEMENTTYPE","PLANNER","EDITDATE"], whereClause) as Ucursor:
    for row in Ucursor:
or
Ucursor = arcpy.UpdateCursor(PlanningProjectTracking, whereClause)
for row in Ucursor:
   for fieldname, value in (('PROJECTNAME', ProjectName),
                            ('EDITDATE', today)):
You do not need to specify all the arguments in the cursor. If a parameter is marked as optional in the documentation, you can omit it.
XanderBakker
Esri Esteemed Contributor
Hi David,
Not sure if this has anything to do with it, but I notice in your original post that you obtain your "SubmitDate" through:
Your "SubmitDate" is a string. I don't know how you have defined the type of your field "SUBMITTALDATE", but if it is a date field, it may be better to provide an actual date. To convert a string to a datetime object see snippet below (but, you need to know the format how it's specified):
from datetime import datetime
submitDate = '24-9-2013'
dateObj = datetime.strptime(submitDate,'%d-%m-%Y')
submitDate = '9/24/2013'
dateObj = datetime.strptime(submitDate,'%m/%d/%Y')
More info on syntax:
http://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior
The alternative could be to read it as an object if it's provided as a date:
SubmitDate = arcpy.GetParameter(1)
See also the Help:
http://resources.arcgis.com/en/help/main/10.1/index.html#//018v00000038000000
Kind regards,
Xander
DavidDenham
I am going to blame this on sleep deprivation from staying up with the my kids.  I finally realized what  you said in your first reply and switched from using the old arcpy.UpdateCursor and used the arcpy.da.UpdateCursor instead.  Then I used the parameters in the correct order and the tool worked fine.
import arcpy
import datetime
# Local variables:
ProjectTracking = arcpy.mapping.ListLayers(mxd, "PlanningProjectTracking", df) [0]
#Set variable to hold SQL statement to query out project to update
Ucursor = arcpy.da.UpdateCursor(ProjectTracking,["PROJECTNAME","STATUS","SUBMITTALDATE","DEVELOPEMENTTYPE","PLANNER","EDITDATE"],whereClause)
for row in Ucursor:
    irow = (ProjectName,ProjStatus,SubmitDate,DevelopeType,PlannerName,today)
    Ucursor.updateRow(irow)
