Append error
1808
09-18-2013 06:44 AM
SHJang
I am new to python and I am using python script for unziping shape file and append the unzip shape file's records to an existing shape file.
The two shape files have a different field structure.
So I am using "schemaType" as "NO_TEST".
The unzip part code works fine but the append part code keeps sending an error:
ERROR 999999: Error executing function. Failed to execute (Append).
Could you anyone can help me what I am doing wrong?
I am using ArcGIS 10.1 version for SDE and Server.
Here is my code:
import sys, zipfile, arcpy, urllib2, os, traceback from os.path import isdir, join, normpath, split from arcpy import env  env.workspace = "E:\\test\\SMCS\\test\\test"  #Set local variables tempshape = "tempshape.shp" schemaType = "NO_TEST" fieldMappings = "Join" subtype = ""  #Connect to the target SDE targetSDE_test = "Database Connections\\sde@[email protected]\\test.sde.SMCS_SDE_TEST2"                   # Function to unzipping the contents of the zip file # def unzip(path, zip):     # If the output location does not yet exist, create it     #             if not isdir(path):         os.makedirs(path)          for each in zip.namelist():         arcpy.AddMessage("Extracting " + os.path.basename(each) + " ...")                  # Check to see if the item was written to the zip file with an         # archive name that includes a parent directory. If it does, create         # the parent folder in the output workspace and then write the file,         # otherwise, just write the file to the workspace.         #         if not each.endswith('/'):              root, name = split(each)             directory = normpath(join(path, root))             if not isdir(directory):                 os.makedirs(directory)             file(join(directory, name), 'wb').write(zip.read(each))  if __name__ == '__main__':     try:         # Get the tool parameter values         #         infile = "E:\\test\\test\\test\\test.zip"         print infile         ###outfol: need to be changed the location to the temp folder in the server         outfol = "E:\\test\\test\\test\\test"         print outfol                      # Create the zipfile handle for reading and unzip ittargetSDE_SMCS         #         zip = zipfile.ZipFile(infile, 'r')         unzip(outfol, zip)         zip.close()                        except:         # Return any Python specific errors and any error returned by the geoprocessor         #         tb = sys.exc_info()[2]         tbinfo = traceback.format_tb(tb)[0]         pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n    " + \                 str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n"         arcpy.AddError(pymsg)          msgs = "GP ERRORS:\n" + arcpy.GetMessages(2) + "\n"         arcpy.AddError(msgs)  try:                       # All polygon FCs in the workspace are MA town shapefiles, we want to append these to the empty FC     fcList = arcpy.ListFeatureClasses("","POLYGON")      for fc in fcList:         print str(fc)                  #process: Append new record     arcpy.Append_management(fcList, targetSDE_test, schemaType, fieldMappings, subtype)      except:     #if an error occured while runing a tool print the message     print arcpy.GetMessages()
Cheers,
SH
SHJang
It turned out my script was OK.  It was my data problem.
Best.
MathewCoyle
Honored Contributor
Are you getting this issue with just SDE or with a regular FGDB as well? Are you sure the SDE FC is editable?
SHJang
Thank you for your reply, mzcoyle.
Actually, it partly worked before.  It added records from an un-zip shapefile without values of each field. It added empty records. So I needed to delete the empty value records.
Here is what I did,
1)my shape file was on a map service, so I stopped the map service
2)Start edit
3) Delete empty records
4) Stop edit
5) start the map service
After I deleted the empty records, I couldn't even add empty records and the code keeps sending the append error.
After your reply, I changed the setting of the shape file in the SDE editable.  But still no luck.
Could you tell me what I am doing wrong?
Best,
SH
SHJang
Best.
