Create Random Points problem
1049
09-11-2013 10:44 AM
GregoryLeonard
Using ArcGIS 10.0, I am wanting to "Extract Multi Values to Points" from several rasters. The trouble is that I am first trying to generate 25,000 random points using the "Create Random Points" tool in Data Management tools, but the tool continues to crash citing the not-too-helpful "Error 999999". I've tried directing output to both Geodatabases and Workspaces, tried using a simple polygon for "Constraining Feature Class" and alternatively a "Constraining Extent" from existing feature polygons and/or rasters. Nothing seems to work; the tool continues to crash.
Please, does anybody know what I might be doing incorrectly, or if there is a known bug at work here? Kind regards, Greg
DanPatterson_Retired
What is the path to the folder you are trying to save to?  Make it simple such as c:\temp
GregoryLeonard
Thanks, tried keeping file path simple using only "C:\".
Yes, sometimes Arc crashes as if file path string is too long.
However, still the same error (Error 999999) with this extremely short file path.
check for NIM reports or report to Technical Support with your data to see if they can replicate it
