Map disappears when size changes
4510
09-10-2013 08:02 AM
BrianBeck
My JS app (v3.6) has two parts: map and form.  Both are in absolutely positioned divs that toggle display.  In other words, when the map is visible, the form is set to display = none and when the form is set to display = block, the map is set to display = none.
I am finding that if I go to the form page and move my browser from one monitor to another or even change the size of my browser window, when I return to the map page the map is not visible.  If I resize the map after returning to the map page, I only see a strip of map vertically in the center of the page and I get 2 error messages in my console that say:
Error: Invalid value for <image> attribute x="NaN" svg.js:15
Error: Invalid value for <image> attribute y="NaN" svg.js:15
How can I refresh the map so that it will show up even if the window size is changed while it is hidden.  As far as I can tell, everything works fine if I change the window size while the map is visible.
MatthewLofgren
Set autoResize to false
var map = new Map("mapPane", {    autoResize : false, //.....
Handle the map resize only when the map is visible:
on(window, 'resize', function() {         // prevent map from resizing when not visible. This would error otherwise    if ( map is visible ) //pseudo code    {      map.resize();     map.reposition();    }      });
also after your map becomes visible, call resize() and reposition()
MatthewLofgren
RanaRameez
You save my life bro!
Thanks a lot!
BrianBeck
Thanks Matt, that worked perfectly.
