Feature Server Edits not Saving
2752
5
09-05-2013 07:09 AM
PaulStephenson
I'm working with an ArcGIS for Server 10.1 - hosted Feature Server in AGOL. I was trying some edit testing and found that I can make changes to feature attributes but they don't keep, even after saving the map. When I try to create a new feature I get the prompt to click on map to create feature, but nothing happens when doing so.
Has anyone else run into this sort of thing, or have suggestions on where to start?
Paul
DanielStauning
Paul,
You mentioned that you're working with ArcGIS Server 10.1, but you've also indicated this is a hosted feature service, can you verify whether this service was published to your own on-premise ArcGIS Server or if it's hosted in the cloud? Registering a local service as an item in your content doesn't necessarily mean it's a hosted service, it just points to the service URL from your on-premise ArcGIS Server.
Would you be wiling to share the service URL or web map ID so that I can take a look?
PaulStephenson
The service was published on our ArcGIS for Server 10.1 on Amazon EC2 (was trying to convey Server-Hosted as opposed to AGOL-Hosted , maybe the wrong term).
PaulStephenson
Sorry to leave this out there so long. At the time I tried to send the link via private message a couple of times but the message would not send for some reason. It looks like we are going a different route to our solution now, but I'll share the service URL until we remove it:
http://arcgis-rcap-349459519.us-east-1.elb.amazonaws.com/arcgis/rest/services/MalvenEC2_for_AGOL_Tes...
Paul
MikeMinami
Esri Notable Contributor
Paul,
Is it ok to make an edit to this service?
Mike
PaulStephenson
Yep, that's fine Mike
Paul
