Formatting label texts with python
923
08-29-2013 12:08 AM
HitomiMaezawa
Hello everyone.
I am new to python programming and just managed to write a code to label features with particular field.
Here is the code that I am using for labeling. After specifying map and layer..
   if layer.supports("LABELCLASSES"):
     for lblclass in layer.labelClasses:
         lblclass.showClassLabels = True
         lblclass.expression = " [type]
*I'm creating labels based on [type] field.
Next step is, set the format for the labels.
I am assuming I want to do something on lblclass.expression line..
like surrounding [fieldname] with text-formatting tags.
So I tried this code, lblclass.expression = "<BOL>[type]</BOL>"
and refreshed, but the labels disappeared, and they reappear when I just type lblclass.expression = "[type]"
It does not show any error message, but it just does not work. Same thing in <ITA><\ITA> code.
Does anybody have any idea how to solve this problem?
Any help will be greatly appreciated.
Thanks in advance!
TrevorHavelka
I believe you have to quote the tags and the interpreter doesn't understand two double quotes.  Try this code.
lblclass.expression = '"%s" & [type] & "%s"' % ("<BOL>", "</BOL>")
TrevorHavelka
HitomiMaezawa
Thank you so much!
It worked perfectly.
I really appreciate it!
StevenMoore
I tried modifying this to use on dynamic labels and I get this instead of the data in the attribute field:
[ATTACH=CONFIG]28558[/ATTACH]
I must be missing some python formatting syntax.
