If else statement
12899
63
08-28-2013 04:39 AM
JamesSmith7
I am modifying a script suggested in a prior thread.  http://forums.arcgis.com/threads/90242-Polygon-Centroid?highlight=jsmith0705
I want to be able to select a line, determine if the ARCLENGTH field has a value greater than zero, return that value if greater than zero, if not return the value from the Shape_Length field.
The script runs with no errors or results.
import arcpy  mxd = arcpy.mapping.MapDocument ("CURRENT") df = arcpy.mapping.ListDataFrames (mxd)[0]  lyr = arcpy.mapping.ListLayers(mxd, "Lot_Lines", df)[0]  for lyr in arcpy.mapping.ListLayers(mxd):  tlyr = lyr  dsc = arcpy.Describe(tlyr)  sel_set = dsc.FIDSet  if dsc.shapeType == "Line":   if len(sel_set) > 0: #If ARCLENGTH value > 0           arcpy.AddMessage(str(ARCLENGTH)) #Return ARCLENGTH value   else:    arcpy.AddMessage(str(Shape_Length)) #Return Shape_Length value
RichardFairhurst
Why does changing the number 0 to a string '0', change the selection from arcLength to shapeLength?  For instance, if len(arcLength) > 0: returns arcLength and if len(arcLength) > '0': returns shapeLength?  The ARCLENGTH field is a string and the Shape_Length field is a double.
I didn't write if len(arcLength) > '0':.  That is a meaningless piece of code and should return an error, since a it is comparing a number with a string.  The alternative you wrote is also wrong.  if len(arcLength) > 0: should return arclength even if it is ' ', which you don't want.  The version James wrote was if len(arcLength) > 1: and it will not return ' ' through '9', which is also wrong.
I wrote if arcLength > '0':, which compares the string with a string and will return arcLength in all cases except where it is equal to ' ' or '0'.  It will return '1' - '9'.  Use the code I wrote and you will get the most correct results.  (It still could fail if you had values like ' 0' or '00', but I considered that to be too unlikely to add more tests to evaluate.)
MichaelVolz
Esteemed Contributor
Try adding some print statements to understand what is actually occurring with your script.
print("The describe statement is returning " + dsc) - You mau need to convert dsc to a string if it is not by default a string
If that returns an expected item then I would continue to add print statements at each critical step to ensure you are getting the expected results.
Please provide results of your print statements so I can further assist you.
JakeSkinner
Esri Esteemed Contributor
Hi James,
If this is a feature class, try the following below.  If this is a shapefile, you will have to update the SearchCursor to use FID instead of OBJECTID.
    tlyr = lyr
    sel_set = dsc.fidSet
    if dsc.shapeType == "Polyline":
        rows = arcpy.SearchCursor(tlyr, "OBJECTID = " + sel_set)
        for row in rows:
            arcLength = row.ARCLENGTH
            shapeLength = row.shape.length
        if arcLength > 0:
            print arcLength
        else:
            print shapeLength
        del row, rows
JamesSmith7
Hi James,
    tlyr = lyr
        for row in rows:
        if arcLength > 0:
            print arcLength
        else:
            print shapeLength
        del row, rows
Jake and Michael,
I am using a feature class.  The script runs with no errors or results.  I am going to try and adjust the SearchCursor and see what happens.
JamesSmith7
Why would changing the SearchCursor to arcpy.da.SearchCursor return an SQL error, whereas, arcpy.SearchCursor does not?  I thought the only difference was arcpy.da.SearchCursor was more efficient?
JakeSkinner
Take a look at the help links.  The arcpy.da.SearchCursor is formatted differently.
arcpy.SearchCursor
http://resources.arcgis.com/en/help/main/10.2/index.html#//018v00000050000000
http://resources.arcgis.com/en/help/main/10.2/index.html#//018w00000011000000
Can you post the exact code you're using in ArcMap?
JamesSmith7
import arcpy
 tlyr = lyr
  rows = arcpy.da.SearchCursor(tlyr, "OBJECTID = " + sel_set)
  for row in rows:
   shapeLength = row.Shape_Length
  if arcLength > 0:
   print arcLength
  else:
   print shapeLength
  del row
  del rows
The error is in line 32, for row in rows: RuntimeError: An invalid SQL statement was used.  I know the select Object ID works, because it changes values depending on the feature selected.
JakeSkinner
Check the name of your OBJECTID field (right-click on layer > Properties > Fields tab).  It may be OID, or OBJECTID1.
JakeSkinner
Also, change arcpy.da.SearchCursor, to arcpy.SearchCursor.
JamesSmith7
The field is named OBJECTID.  Changing the cursor back to arcpy.SearchCursor eliminates the SQL Error.  But, the script runs with no results.
