sequential number for each class in a field
2173
08-27-2013 03:15 AM
nadeemfareed
hello everyone.
i know a script which is used for sequential number generation in a field. the script is given below.
Expression:
autoIncrement()
Expression Type:
PYTHON_9.3
Code Block:
rec=0
def autoIncrement():
global rec
pStart = 1 #adjust start value, if req'd
pInterval = 1 #adjust interval value, if req'd
if (rec == 0):
  rec = pStart
else:
  rec = rec + pInterval
return rec
this is very useful when we want to calculate the sequence number for whole field.
but i am looking for same thing in a different manner. i have point shapefile which have different classes, each class have more then 100 records. i want to generate the sequence number for each class in a single field. e.g..
class1= 101 records, class2=105 records, class3=110 records.these records are present in classes field
i have another field name seq.numer. in this field i want to generate sequential number for each class in this field starting from 1 for each class. i hope you understand what i mean.
Nadeem Fareed
JakeSkinner
Esri Esteemed Contributor
Hi Nadeem,
If you don't have to use the field calculator, the below should work:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
list = []
rows = arcpy.SearchCursor("Table")
for row in rows:
    Class = row.getValue("Class")
    list.append(Class)
del row, rows
#remove duplicates from list
list = dict.fromkeys(list)
list = list.keys()
for n in list:
        rec = 0
        rows = arcpy.UpdateCursor("Table")
        for row in rows:
            if row.Class == n:
              pInterval = 1
              if (rec == 0):
                rec = 1
                row.SeqNumber = rec
              else:
                row.SeqNumber = rec
            rows.updateRow(row)
del row, rows
