In a 10.1 map service, I successfully used many subqueries on my map services.. An example where clause would be: AIRCRAFT_ID IN (SELECT AIRCRAFT_ID FROM COUNTRY_AIRCRAFT WHERE COUNTRY_ID = 5)
All data is stored in a file geodatabase. After the upgrade to 10.2, this no longer works. I didn't change the code, or the gdb. Worked flawlessly in 10.1 for many moons.Has anyone experienced anything similar?
