Tutorial example on help menu for Empirical bayesian Kriging doesn't work.
6862
8
08-22-2013 07:36 AM
BarryBarrios
I'm trying to run this code below:
import arcpy
arcpy.EmpiricalBayesianKriging_ga("ca_ozone_pts", "OZONE", "outEBK", "C:/gapyexamples/output/ebkout",
                                  10000, "NONE", 50, 0.5, 100,
                                  arcpy.SearchNeighborhoodStandardCircular(300000, 0, 15, 10, "ONE_SECTOR"),
                                  "PREDICTION", "", "", "")
But it doesn't work because I don't have the dataset ca_ozone_pts. I downloaded the Tutorial data and in the folder
C:\arcgis\ArcTutor\Geostatistical Analyst
I only see ca_ozone.gdb an din there I don't see ca_ozone_pts. Please help.
SteveLynch
You can use the feature class called O3_Sep06_3pm in the ca_ozone file geodatabase.
Rename the feature class or modify the code snippet.
BarryBarrios
Attached is all the files I see for ca_ozone.gdb. There's no ca_ozone_pts.
BarryBarrios
Oh ok, great I used what you suggested, to use 03_Sep06_3pm. that did the trick. For the second example:
inPointFeatures = "ca_ozone_pts.shp
What do I use for "ca_ozone_pts.shp"?
SteveLynch
# set this to the location where the feature class is in, viz.,
arcpy.env.workspace = "C:/arcgis/ArcTutor/Geostatistical Analyst/ca_ozone.gdb"
# Set equal to the name of the feature class, viz.,
inPointFeatures = "O3_Sep06_3pm"
LiKi_Da
Could you please upload the example tutorial data that you downloaded?
SteveLynch
The "tutorial" page at http://resources.arcgis.com/en/help/main/10.2/index.html#//0031000000nz000000 suggests that you go to
https://customers.esri.com/index.cfm?event=login.show to download the data.
Have you tried that?
Steve
LiKi_Da
Steve
I do not have the customer account. If you have the examples, please send them to me. In addition, do you know how to use EBK with the barrier (boundary)?
Thank you.
SteveLynch
EBK with barriers does not exist.
