Help - exporting data frame (not page layout) to PNG via arcpy
1794
08-14-2013 05:19 PM
AnthonyCheesman1
Good morning all
I'm trying to pull together some code to export the data view (not the page layout view) to PNG. The issue I'm having is that when I use the df variable in the ExportToPNG function, I am getting an Assertion Error. If I substitute df for "PAGE_LAYOUT" the script runs, but the output is not what I'm looking for.
Any ideas how to solve this?
This is what I've got so far:
import arcpy import os from arcpy import env from time import localtime, strftime  # Set workspace  arcpy.env.workspace = r'd:\gis\aerialtracking\output' ws = arcpy.env.workspace if str(os.path.exists(ws)) == "False":     os.makedirs(ws)  # Set time variable and print output variable  printtime = strftime("%Y%m%d_%H%M", localtime()) print printtime pngname = "mapexport_" + printtime + ".png" print pngname  # Set mxd  mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)  #Export PNG  arcpy.mapping.ExportToPNG(mxd, pngname, df, df_export_width = 1600, df_export_height = 1200, world_file = True)  #delete variables  del df, ws, printtime, pngname, mxd
Edit: I didn't actually get this above code to run, but I got similar code running thru the Python window in ArcMap.
>>> arcpy.mapping.ExportToPNG(mxd, r'D:\gis\aerialtracking\output\test.png', "PAGE_LAYOUT") >>> arcpy.mapping.ExportToPNG(mxd, r'D:\gis\aerialtracking\output\test.png', df) Runtime error <type 'exceptions.AssertionError'>:
RhettZufelt
MVP Notable Contributor
import arcpy
import os
# Set workspace
    os.makedirs(ws)
print printtime
print pngname
# Set mxd
df = arcpy.mapping.ListDataFrames(mxd)[0]
#Export PNG
#delete variables
Suspect the issue is that you are sending a list of dataframes to the export command rather than just one df as ListDataFrames always produces a list, even if only one item in it. the above code will use the first dataframe in the list (index [0]).
See if that gets it working,
R_
RhettZufelt
import arcpy
import os
# Set workspace
    os.makedirs(ws)
print printtime
print pngname
# Set mxd
#Export PNG
#delete variables
R_
AnthonyCheesman1
Spot on! Thank you - that has worked well.
Kicking myself as I saw that in the example code but stupidly thought it was a comment, therefore didn't include it.
RhettZufelt
Glad it worked for you.
Also, I see you gave me a point with the up arrow, would you might selecting the checkbox as answered also?
Will give me credit for it and also mark it answered for people searching similar issues in the future.
R_
