Configuring ArcGIS 10.2 Server's Auth. WITH MS Active Directory Federated Server
3692
08-10-2013 12:10 PM
MAWashington
I found ArcGIS.com has support for MS Active Directory Federated Server (http://resources.arcgis.com/en/help/arcgisonline/index.html#/Configuring_Active_Directory_Federation...).
It makes since to support SMAL-Claims Based Authentication for their online �??hosted services�?�.
However, our deployment will be �??on premise�?�.  But still will require the ADFS support.
I need help Configuring Active Directory Federation Services 2.0 against ArcGIS 10.2!
Please feel free to contact me directly: kevin@rgia.org , 206.212.6511 - I am most desperate!
DerekLaw
Esri Esteemed Contributor
Hi Kevin,
FYI: when you say "on premise ArcGIS.com", I believe you are referring to Portal for ArcGIS, a new extension to ArcGIS for Server in the 10.2 release.
I found ArcGIS.com has support for MS Active Directory Federated Server ... However, our deployment will be �??on premise�?�. But still will require the ADFS support. ...
The current release of Portal for ArcGIS does not support SAML authentication. This is being considered for a future release. FYI, an ArcGIS 10.2 Server site can be registered as a �??federated server�??, with an on-premise deployment of Portal for ArcGIS.
Hope this helps,
